Yaw sensor
Old 07-13-2010, 08:59 PM
Jason
Jason's Avatar
CI 4-5-6-7 Veteran
Default Yaw sensor
If you unplug (remove) the yaw sensor in the passenger floorboard, you will get a "Service Active handling" message when you start the car. So does that mean AH/TC is disabled and I don't have to worry about remembering to turn it off every time I shut the car off in grid?
Old 07-13-2010, 09:09 PM
drivinhard
Support Corvetteforum!
drivinhard's Avatar
yeah but it kills the ABS to
Old 07-13-2010, 09:11 PM
Jason
Jason's Avatar
CI 4-5-6-7 Veteran
Damn, I suck without ABS. There are black marks down the NSS backstretch to prove it.
Old 07-13-2010, 09:14 PM
gmccreary
gmccreary's Avatar
When I pulled my passenger seat I did not see the yaw sensor? Where is it?
Old 07-13-2010, 09:32 PM
Jason
Jason's Avatar
CI 4-5-6-7 Veteran
Under the carpet, near the tunnel.
Old 07-13-2010, 10:01 PM
Bill Dearborn
Bill Dearborn's Avatar
Received 8,926 Likes on 5,332 Posts
He is talking about a C5. On the C6 the lateral G sensor and the yaw sensor are both located in the center stack near the radio.
The C5 has the yaw sensor in the center stack and the lateral G sensor under the passenger seat. Disconnecting the lateral G sensor should kill the Traction Control and Active Handling without affecting the ABS. It isn't needed for the ABS function.
Bill
Old 07-13-2010, 10:16 PM
davidfarmer
davidfarmer's Avatar
I agree with Bill, I wouldn't expect it to kill ABS, although you should test it before turn 1 at your next event!
Old 07-13-2010, 10:20 PM
geerookie
geerookie's Avatar
Not true! I have both sensors out and ABS still works.
Old 07-13-2010, 10:22 PM
gmccreary
gmccreary's Avatar
Bill
I have an 01 C5Z too.
Old 07-13-2010, 10:40 PM
drivinhard
drivinhard's Avatar
Learn something everyday. I guess I was basing my assumption from previous experience of having the EBCM going out where everything was kaput.
Since I am helping (or trying to, lol) ken with his car with this exact problem (lat sensor codes), I just tested it. The ABS does in fact work, as does the TC. All this with a service active handling MIL and auto shut off of the AH. I suppose it just ignores any AH/car attitude inputs, but keeps the TC and ABS in check.
good to know
Old 07-13-2010, 11:00 PM
SouthernSon
SouthernSon's Avatar
Location: Deal's Gap 2004 NCM Motorsports track supporter
Received 1,103 Likes on 717 Posts
Jason, keep me updated on the sensor. I like that idea of default to nothing except ABS!
Old 07-13-2010, 11:49 PM
sperkins
sperkins's Avatar
I read through this quickly. Are y'all saying the sensor is under the pass side BCM panel area?
Old 07-14-2010, 01:19 AM
fatbillybob
fatbillybob's Avatar
awesome info guys. I hate it when I forget to press the button to kill the TC. I'm going to try your ideas
Old 07-14-2010, 06:24 AM
geerookie
geerookie's Avatar
Nope.....On a C5 the yaw sensor is under the carpet under the passenger seat. When you take the seat out there is a bump near the tunnel and towards the front of the seat.
The other sensor is behind the HVAC controls on the drivers side mounted with 3 bolts at the back/bottom of the aluminum framework which holds the radio and HVAC controls.
Old 07-14-2010, 07:32 AM
Jason
Jason's Avatar
CI 4-5-6-7 Veteran
Mark, did you say TC stays on? that doesn't do us any good then.
Old 07-14-2010, 12:03 PM
BERETTA
BERETTA's Avatar
Yaw sensor is below the radio/hvac control head- the lateral g sensor is under the passenger seat, its actually bolted to a bracket that is glued to the floor pan from the factory
The yaw sensor is not under the passenger seat.....
Old 07-14-2010, 12:35 PM
drivinhard
drivinhard's Avatar
it would kick on during a straight line accel, but I'm (assuming) that it wouldn't kick in an AH situation. I didn't fling it around to find out
To Yaw sensor
Old 07-14-2010, 12:52 PM
sperkins
sperkins's Avatar
Or under the Suzuki bridge at 5,00rpm.
Old 07-15-2010, 01:36 PM
sperkins
sperkins's Avatar
I'm having a hard time picturing either one of these. My car is gutted and I don't see anything like this. Anyone got any pics?
BTW - mine is a '99 so I don't have AH, but I do have TC.
Old 07-16-2010, 01:12 AM
RX-Ben
RX-Ben's Avatar
lat g is just under the left rail of the pass. set mount, about 6" from the left-side seat stud in the front. It's location reqs some custom work in fab'ing up a racing seat mount (simple straight mount will not work).
Quick Reply: Yaw sensor
