Windows in trailers??
I've been thinking of putting a window in my trailer (24' Pace). I sleep in it at the track. The shop (it's in for some minor fixes) has a 24x36 tinted sliding window in stock. Anyone else done this? I like the idea of getting more light when I'm running the AC it's a bit claustrophobic.
TIA,
John
TIA,
John
Location: I tend to be leery of any guy who doesn't own a chainsaw or a handgun.
I'm in the process of trying to find a window for my trailer. So far I've had very little luck finding something acceptable that will fit between the side structure "studs". I have about 11" of clearance, and most RV windows are too wide.
That's a large window you're describing. How does it fit within all the basic skeletal structure?
They will weld a reinforcement frame around the window to reinforce the cut. Jim's Motors (Flying A Motorsports) in Missouri is doing the work.
I was quoted 5 hours labor to do the window.
If you add them have a way to cover them from the inside so if they are broken there is still no easy entry into the trailer.
Jim
Jim
To be honest the easiest way to get into a Pace trailer is the side door. A big screwdriver right at the deadbolt and you're in. The deadbolt only travels about 3/8". No big deal for a crow bar.
I sleep in mine often and the lack of a window reminds me of being in a sub. I would add a window in a heartbeat. You will want a way to hang something on it though to block sun and when the lights are on at night.
You can cut into the side of almost any trailer so I worry less about security.
U r right but I have a round master lock on my door too, along with 2 other locks and an alarm system--they would have to cut a big hole in the door to get in--I have over the bar locks on rear--can get them at trailer stores. Can send u pics if you send email i havre the guarded hasp system seen in the previous entry by z11409
I had them put the window in yesterday. I'm looking for accordion/pleated solar shade for the inside. I have trailer and contents insured, so I'm just not going to worry too much.
I'll let you guys know if it was a bad idea...
