Autox driver takes out $1500 of timing equipment
Old 08-11-2010, 08:33 PM
BrianCunningham
BrianCunningham's Avatar
Location: Boston, Dallas, Detroit, SoCal, back to Boston MA
Default Autox driver takes out $1500 of timing equipment
I was working gate @ the time.
I wondered why this heat was taking so long.
Old 08-11-2010, 08:58 PM
shakedown067
shakedown067's Avatar
St. Jude Donor '12-'13
Ouch. I've come through the timing lights sideways twice (didn't even hit a cone the first time). Never close to the lights though. That would be a bad day. Luckily we usually place ours quite a ways out.
Old 08-11-2010, 09:37 PM
rasrboy
rasrboy's Avatar
But I do love the HUGE track layout. In our area they are all small tight tracks except the old Ford Plant we run at.
Old 08-11-2010, 09:48 PM
BrianCunningham
that was the SHORT course
Old 08-11-2010, 10:05 PM
AverageVetteNut
AverageVetteNut's Avatar
Cruise-In 9-10 Veteran
CI-X Auto-X Champ (race tires)
St. Jude Donor '07-'09
That the akron Sports car club, or NORA? Was @ Northfield park 2 weekends ago running there.
my 1st event in the Z06 2 years ago ( on the GY tires ) I spun @ the finish and hit the timer... everyone was more worried about my car than the timer head ( and I was the opposite, thinking that I ruined the day's runs ).
Old 08-11-2010, 10:46 PM
NTMD8R
NTMD8R's Avatar
And that is a very good reason to have a STOP BOX !!!!
I noticed this would have been a "flying finish" box.
Why don't track/course designers make it a Stop Box?
Where you MUST come to a complete stop
(someone must remove a LARGE cone) for people to exit.
I've seen so much of this kind of thing happening, because people
feel they need to race through the lights, and then the stop box
is not long enough to accommodate aggressive braking.
Make a true stop box, and people will HAVE to control their driving
to cross the lights, and come to a controlled stop within the box.
Hitting any cone in the Stop Box should be a 5 second penalty.
After all, this IS about "Driver Training".
Old 08-12-2010, 12:05 AM
vettehardt
vettehardt's Avatar
Hey Aaron, we'd love for you to come over to grissom for one of our events. Plenty of room there and always a great weekend. Just go to www.indianaregion.org for flyers.
Old 08-12-2010, 12:21 AM
vettehardt
vettehardt's Avatar
Because they are more trouble than they are worth. People will still try to get to the lights as fast as they can. When they go to brake, they can end up loosing it and taking out the lights anyways. Also the cars will sometimes be going so slow through the lights that it double tripps them screwing up the next guy's run. You are better off having your last gate/cone with enough room afterwards for the driver to get the car straight and under control before going throught the lights. Then after the lights having ample shut down room. If there isn't room for that you then can use a stop box, but not something too close to the lights. Whenever we do have a stop box type deal, any cone hit after the finish is a DNF. Also if they don't come to a complete stop it is a DNF.
My dad has is own equipement for timing and do alot of the indiana region NCCC events. In about 15 years of timing, we have only had the lights hit a few times. Luckly every time it was the reflector. We carry backups of both lights, reflectors, and cables just incase.
Last year we had a guy driving a camaro loose it and take out the reflector box. Plastic pieces were every where! Unfortunatly the worst we ever had was the next day we had a guy in a yellow C6 loose it and hit our trailer. In the process he ran over the cords going to the lights and tore those up. The only good part about it was it was at the end of the day and not too many people lost out on runs. I was on the starting line waiting to go out when it happened.
Old 08-12-2010, 12:44 AM
mgarfias
mgarfias's Avatar
That beats what I saw happen ~ 5 years ago in phoenix. **** poor course design had a high speed sweeper right before the exit lights. And the timing trailer was parked close to the lights. You know how people hang out around the trailer? Yeah, well, a helo flew in to get one of them. I heard he lost the leg. No real surprise there, it was crunched between an S2000's RF fender and the tongue of the trailer.
I don't mess with autox now, and just HPDE and make sure my people are safe (behind walls, etc).
Old 08-12-2010, 07:25 AM
PA Z06
PA Z06's Avatar
pretty crazy,
Old 08-12-2010, 09:04 AM
c4cruiser
c4cruiser's Avatar
When I set up courses for our association's event I use a stop box. We usually allow up to 75 feet for a straight run to the lights, another 90 to 100 feet for the car to come to a complete stop. The finish gates are about 15-20 feet apart and the stop lane tapers to 10 at the location of the stop cone. The lights are placed about 5 feet on either side of the finish cones.
There is a cone in the middle of the lane that a worker must remove before the car can proceed at 5 MPH out of the lane. Any cone hit after going through the lights is an automatic DNF.
Hitting the lights is a DNF and the driver pays for any costs to repair/replace the equipment.
Old 08-12-2010, 09:14 AM
The Panther
The Panther's Avatar
Exact same thing happened at a BMW/PCA event I was at last month. Yellow C5Z did a 180 at the finish and hit the timing gear.
Old 08-12-2010, 10:13 AM
TedDBere
TedDBere's Avatar
Just put the timing gear 10 feet off the cones, both left and right.
Putting them next to the finish cones is just asking for it. Cones get hit so if you put the gear by the cones then it's going to get hit too.
This looks like poor design. Plenty of room to move the timing gear away from the cones on that runway.
Look at the first two videos in my sig to see where they are placed at National events.
Old 08-12-2010, 10:25 AM
Kubs
Kubs's Avatar
Received 1,754 Likes on 941 Posts
2023 C5 of the Year Finalist - Modified
St. Jude Donor '09-'10-'11
The timing equipment should be much farther from the finish cones. I have gone through the stop box sideways before and never worried about hitting the lights because they are usually far away.
It is actually put on by a new club called Vettesports hosted by a buddy of ours. Go to Vettesports.com for details. I will be there the 22nd if you want to come.
Old 08-12-2010, 11:38 AM
grantar2
grantar2's Avatar
As one who has spun out at the finish I can feel for the guy. For reasons mentioned a stop box isn't the right answer for a lot of courses. You don't see them used at divisionals, nationals, or pro-solo's. I am surprised at the price, I have been told the components are significantly less expensive, at least the ones we use in Cal Club. The other side of the coin is we have spares for every component, multiple spares for many. Looking at the video the course wasnt difficult, but the guy wasn't reckless, sounds like he had a passenger, stuff happens in racing. There was one comment about not doing autox and only HPDE, but I have seen as many people hurt and cars damaged at driving events as autox, so I am not sure the comparision holds. Safety is the #1 topic in my region, I assume it is in most.
The advantage HPDE is that you get more than 3 minutes for your hard days work. 10-15 minutes if it's a practice event.
Thanks for the post, good discussion.
Old 08-12-2010, 02:18 PM
L98Terror
L98Terror's Avatar
W. Detroit Events Coordinator
Cruise-In VI Veteran
Cruise-In VII Veteran
Cruise-In VII Autocross Champ
Damn, I miss that place
Old 08-12-2010, 02:59 PM
RX7 KLR
RX7 KLR's Avatar
I think someone was going for dramatic effect with the thread title... That was a single head taken out, even wireless heads are not $1500.
To Autox driver takes out $1500 of timing equipment
Old 08-12-2010, 03:42 PM
Han Solo
Han Solo's Avatar
Very common course design fail. Drivers should not be held accountable for that.
As mentioned set timers away from the finish cones. My personal beef is courses that have sharp transitions near the finish. Course designers will argue they are trying to slow the cars down at the finish. I say set the finish far enough back to give plenty of braking room AFTER the finish and have the last transition far enough away from it to allow the cars to be on the gas and going straight at the finish timer.
I've even heard of timing trailers hit with this kind of foul up.
Old 08-12-2010, 06:20 PM
waktasz
waktasz's Avatar
Bingo, first thing I thought. Lights are too close to the actual course boundary. Go two feet too far and you smash them.
Old 08-12-2010, 07:08 PM
naschmitz
naschmitz's Avatar
Quick Reply: Autox driver takes out $1500 of timing equipment
