C4 Track Car Newbie
C4 Track Car Newbie
Hi Everyone, hopefully I'm posting in the right section now...:o. I've adored corvettes all my life and I finally just bought my first Corvette, an '86 coupe. I plan on turning it into a track car for road racing. I was hoping someone might have some advice as to where to start. Are there any essentials that I should know about? I realize this is a pretty expensive hobby but I'm trying not too spend too much money. I figured I could do my first couple events with the car relatively stock. I'll be getting some nice General Exclaim UHP tires and Carbonetic pads. Afterward I'm thinking polyurethane suspension bushings, kill some weight (AIR system, carpet, etc.), exhaust, and intake. Also, the car didn't come with the Z51 package. I'm doing this for fun and more importantly to learn A LOT so does anyone have any good advice? Thanks!
Power steering can be a problem, good fluid is essential. If you still have an issue upgrade to a better pump.
Safety equipment comes before performance in my opinion.
If the bushings and shocks have not been replaced an upgrade to poly bushings will make it feel more solid.
C4's are fun and reasonably priced to play with on track!
When is your first / next event?
Where is it?
Right now with NASA SE there are only a few of us with C4's.
Is this going to be a dedicated track car or a weekend toy?
Are you going to do 10+ events a year or 1-3?
I do 10+ events a year and this winter the modifications will be a proper seat and harnesses, a head and neck restraint, and if I have any money left over rebuild the spare motor.
My 92 is built to NCCC group II specs also fits NASA TTB specs.
Yes I've rebuilt the suspension, replaced hubs, opti, radiator, etc.
After the fiasco with the last set of rear hubs I keep a spare set on the shelf.
I gots lots of wheels and tires as well.
Run away now before you get in too deep
Where is it?
Street pads /fluid will last bout three sessions on a decent road course before the pedal goes to the floor .
You might get two turns warning , then , well, if your lucky you just throw alot of sand in the air .
All the moving parts in the suspension if original are done , might as well change them now .
Valve cover gaskets ... I blew out the gasket on the distributor on mine at Gingerman . ( small leak)
Click my name and then the link for threads I've started. I've made some threads as I finished projects on my track car. Drop as much weight as you can, and sell the parts. Under drive pulleys helped my stock non-cooled power steering system live a long life. Definitely get track pads.
Rob, might want to do a compression test.
Sounds good! Mine started having more and more blow by, ended up with 70 PSI on #7. It had cracked rings.
5k RPM for 80% of a 15 min session, 5 sessions a day can't be good for longevity. Plus I want more power - 383 time, I'm gunning for the spec c5z guys next year
Not having cooling ducts improves the remembering of "Brake Hard, short time, stay off them if you don't need them" lessons.
Track tires - NOT until you can make your street tires sing the entire session, each and every session.
Just my $0.02 and what I tell all my students
Awesome stuff guys, thanks for all the suggestions.
@jaa1992 - my first event will be w/ NASA-SE at CMP in November. See you there? This will be my dedicated track car but I want it to be street legal enough to drive to the track. I plan on doing as many events as I can afford and attend! So I'm shooting for 3-5 maybe?
I was looking into those cooling ducts for my wish list. I wasn't sure how much they would help but i guess that answers my question.
Any suggestions on power steering fluid?
CMP is hard on brakes, I won't be there in Nov. My neice decided she was getting married that weekend. I'll be at Road Atl in Dec.
Look for the C5 mafia - Jeff, Jason, Scott, Mark, etc. They will keep you safe and tell you more stories . . . . . . .
