Negative camber, please to explain
I figure you road race guys will know:
http://www.autoblog.com/2010/08/12/c...prove-handling
How would this work? Isn't the point of camber to adjust the tire's contact patch? In this case, the asymmetrical tire simply adjusts it back, negating all the benefits.
I feel like either I'm stupid, or auto journalists are. Am I missing something?
It sounds to me like this tire is geared toward ricers who lower the crap out of their car and just drive on the street. They never TRULY corner hard enought to take advantage of the negative camber.
If I read this correctly the ONLY purpose of this tire is to create a flat contact patch for cars driving under normal conditions that have a lot of negative camber.
I also agree that lots of negative camber on a street car will ruin around town handling and highway driving and wear out tires prematurely.
This tire is designed for those who SHOULDN'T be running negative camber to still be able to slam their cars and not have the poor tire wear with negative camber.
Under race/track conditions, this tire will roll over on itself like any tire without camber.
Received 1,731 Likes
2023 C5 of the Year Finalist - Modified
St. Jude Donor '09-'10-'11
Goodyear made cambered race slicks about 7 yrs ago for a season or two. I never tired them, but it was a 50/50 split regarding pro/con opinions for those that did.
This seems like a ridiculous idea for a street tire.
If you don't want to change camber when you get to the track, it has a purpose. It should give you better street tire wear than if you run regular tires on the street and it lets you have big negative camber for the track when you change to track tires.
Not stupid if you don't want to jack with camber every time you run a track day or run an autocross and you want to run 2 degrees of negative camber on your race setup.
