Upgraded motor mounts for LT-1/4 engine?
Old 08-17-2010, 08:37 PM
leadfoot2
leadfoot2's Avatar
Default Upgraded motor mounts for LT-1/4 engine?
Anybody know of any stiffer motor mounts - poly, etc. - for the late model C4 (92-96) with the LT-1/4 engine? Haven't been able to find a thing.
Old 08-17-2010, 09:05 PM
John Shiels
John Shiels's Avatar
Location: Buy USA products! Check the label! Employ Americans
Try VBP?
Old 08-18-2010, 08:17 AM
BrianCunningham
BrianCunningham's Avatar
Location: Boston, Dallas, Detroit, SoCal, back to Boston MA
The only alternaatives I've seen are custom solids
Old 08-18-2010, 12:54 PM
Locke
Locke's Avatar
Default LT4 Solid Engine Mounts
Take a look at these:
http://s606.photobucket.com/albums/t...otor%20Mounts/
I never tried them on a car because they are not legal in NCCC Group 1 but we may get around to putting them on Joe's Group III car some day.
Old 08-18-2010, 04:49 PM
leadfoot2
leadfoot2's Avatar
Tried VBP - no go.
I would think using solid mounts with a torque tube setup would put alot of stress on the transmission, no?
Nice work Locke.
Old 08-18-2010, 05:41 PM
ScaryFast
ScaryFast's Avatar
For what purpose are you using the car? I've also searched extensively to no avail. Quite frankly, the stock ones are pretty good, I still use them in the race car. In 8 years I've replaced them only once, and one of them wasn't torn but was looking pretty rough.
Solid is nice but not required. My fabricator quoted me about $60 a side to make a set IIRC.
Old 08-19-2010, 01:03 PM
leadfoot2
leadfoot2's Avatar
It is a track dedicated car (road racing). I would like to reduce the movement of the engine on rapid acceleration/deceleration which can be quite a bit. Rather get that torque transferred to the ground plus the exhaust pipes are hitting the body.
Old 08-20-2010, 12:10 PM
BrianCunningham
How about a torque strap?
Old 08-20-2010, 04:56 PM
leadfoot2
leadfoot2's Avatar
You'll have to explain that concept to me.
Old 08-22-2010, 01:52 PM
BrianCunningham
It's a connection, usually a turnbuckle that can be adjusted, between the frame and the engine to limit movement.
http://www.ls1gto.com/forums/showthread.php?t=73996
http://www.fordmuscle.com/archives/2000/04/quicktips/
Old 08-22-2010, 04:03 PM
ScaryFast
ScaryFast's Avatar
Are you sure you don't just need new ones? I don't have anywhere near that movement you're describing. And I do more than just drive my C4 to church on Sunday...
To Upgraded motor mounts for LT-1/4 engine?
Quick Reply: Upgraded motor mounts for LT-1/4 engine?
