freshening up the helmet
Old 08-29-2010, 04:59 PM
drivinhard
Support Corvetteforum!
drivinhard's Avatar
Default freshening up the helmet
any good ideas for keeping a helmet fresh, less stinky w/ age?
Old 08-29-2010, 05:02 PM
Jason
Jason's Avatar
CI 4-5-6-7 Veteran
Febreeze
Old 08-29-2010, 05:06 PM
Brent Dalton
Brent Dalton's Avatar
Let me know if you find anything Mark, as mine is starting to get bad this year.
Old 08-29-2010, 05:12 PM
Bill Dearborn
Bill Dearborn's Avatar
Received 8,911 Likes on 5,325 Posts
I got something called Molecule Refresher through the local circle track supply store. It cost $6 bucks for a 4 oz bottle last year. Part number was MOLMLRE-4.
Bill
Old 08-29-2010, 05:35 PM
yakisoba
yakisoba's Avatar
Those fabric softener dryer sheets. I pop one of those in my helmet after track days, and it sucks up excess moisture and makes it smell better.
Old 08-29-2010, 05:43 PM
davidfarmer
davidfarmer's Avatar
we have a big vacuum carpet cleaner thingy with a furniture attachment. Occasionally, I'll saturate my helmet with cleaner and suck it out. A shop vac would probably also work
Old 08-29-2010, 06:50 PM
PA Z06
PA Z06's Avatar
x2 it has worked well for me over the years
Old 08-29-2010, 07:35 PM
Fastguy
Fastguy's Avatar
St. Jude Donor '03-'05
I just wash mine in the kitchen sink with some laundry detergent.
Old 08-29-2010, 09:04 PM
yakisoba
yakisoba's Avatar
No one has mentioned taping it to the top of the car and taking it through the car wash.
Old 08-30-2010, 10:06 AM
96CollectorSport
96CollectorSport's Avatar
Location: If you don't weigh in you don't wrestle Road America
Depending on what brand helmet you have you can send them in to be re-lined. A friend had Simpson reline his after someone blew chunks in it. Not sure what it cost, I think around $100.
Old 08-30-2010, 10:19 AM
sperkins
sperkins's Avatar
That doesn't make your mullet smell like a Bounty sheet?
Old 08-30-2010, 03:56 PM
yakisoba
yakisoba's Avatar
*shrug*
Chicks dig it.
Business in the front, party in the back, smells good all over.
Old 08-30-2010, 07:36 PM
Slalom4me
Slalom4me's Avatar
Originally Posted by drivinhard
Any good ideas for keeping a helmet fresh, less stinky w/ age?
How old is the helmet? Overdue for replacement?
If not.
Be wary of applying anything that might attack the foam liner.
Consider buying or making a helmet dryer. The DIY route is
straightforward. Small cooling fans for electronic devices are
readily available in various sizes and current/voltage draws.
I have a 3" 12VDC/2.8W fan that I power with a variable voltage
power supply (1.5V to 12V). When set to 6V, the power supply
spins the 12V fan at a satisfactory noise/volume level. For
track use, consider rigging something that will power the fan
from a cigarette lighter socket.
An inline fuse with a suitable rating is always a good feature
to include in a circuit.
Old 08-30-2010, 07:50 PM
SouthernSon
SouthernSon's Avatar
Location: Deal's Gap 2004 NCM Motorsports track supporter
Received 1,101 Likes on 715 Posts
same here. So far no adverse effects.
Old 08-30-2010, 11:46 PM
SIK02SS
SIK02SS's Avatar
x3 on dryer sheets
Old 09-01-2010, 08:26 AM
bobmoore2
bobmoore2's Avatar
I just got the liner saturated with water, then squished the water out of the foam. Repeat several times until the water coming out of the foam is clean. Then let it air dry. It smells OK again now.
To freshening up the helmet
Quick Reply: freshening up the helmet
