weather stripping question
Old 08-29-2010, 10:45 PM
MJM
MJM's Avatar
Default weather stripping question
Drivers side weather stripping started sagging and flapping around at Willow Springs.
I might be able to just glue it back, but I am open to buying a new piece. The dealer (I was dropping a friend off, so I checked) wants $340 for a new piece!
What do the racers do? (no I am not open to using duct tape!)
Matt
Old 08-30-2010, 12:26 AM
froggy47
froggy47's Avatar
If it's in good shape, just glue it.
They pop out very easy.
Had mine pop out & hit me in the helmet once, it's had racer tape on it ever since.
Seems that GM might have thought of the consequences of having it pop out at 100 plus mph on a track, but hey, just one of those little details.
Old 08-30-2010, 08:34 AM
Jason
Jason's Avatar
CI 4-5-6-7 Veteran
Nice seat.
Old 08-30-2010, 09:11 AM
John Shiels
John Shiels's Avatar
Location: Buy USA products! Check the label! Employ Americans
Vendors here should have it like ZIP, MA, or Ecklers if it is shot.
Old 08-30-2010, 07:12 PM
Slalom4me
Slalom4me's Avatar
Originally Posted by MJM
Driver's side weather stripping started sagging and flapping
Racers have better things to spend $340 on. Repair the existing weatherstrip.
Here is how:
Buy
- 3M Super Weatherstrip Adhesive (pn# 051135-08008)
- 3M General Purpose Adhesive Cleaner & Wax Remover (pn# 08984)
Check with local autobody paint and supply houses. I doubt
that Pep Boys and their competitors will carry the products
but ...
Use the 3M General Purpose Adhesive Cleaner & Wax Remover
to prepare (clean) the surfaces to be bonded and later for clean
up, if required. Obvious warnings: wear gloves, work in a well
ventilated area, avoid inhaling the fumes - no joke.
3M Super Weatherstrip Adhesive comes in different colours, so
be sure to get black, not yellow.
Follow directions on the box about applying the adhesive in two steps:
  1. Apply a first coat to each side to be bonded - WITHOUT
    placing them together.
  2. Let this first coat dry then apply a second coat and join the
    parts together.
Be prepared to hold the sections in place together until they
have bonded well enough not to droop. (ie: be prepared to
stand there for a least 15 - 20 minutes applying pressure.)
Incidently, these products aren't just for major weatherstrip
repairs. They can also be used to make nearly invisible fixes
to aged weather strip that has developed cracks/fissures.
Old 08-30-2010, 07:23 PM
Slalom4me
Slalom4me's Avatar
Some product information:
3M™ Super Weatherstrip Adhesive, 08008, 5 oz tube, Black
3M™ General Purpose Adhesive Cleaner, 08984, 1 Quart
Old 08-31-2010, 12:31 AM
MJM
MJM's Avatar
Here is how:
Buy
but ...
    parts together.
Many thanks!
Matt
To weather stripping question
Quick Reply: weather stripping question
