Running Anti-freeze on track.....
Old 08-30-2010, 02:48 PM
Falcon
Falcon's Avatar
Default Running Anti-freeze on track.....
Hey guys,
Here's a thread where anti-freeze was involved in causing a crash. Both guys suffered a lot of damage to their cars. Luckily, they escaped physical injury.
Think twice before racing with anti-freeze in the radiator.
Old 08-30-2010, 02:50 PM
AU N EGL
AU N EGL's Avatar
Not good
Old 08-30-2010, 03:11 PM
Rob31
Rob31's Avatar
I did a day at Gingerman last April . I suggested they change out the antifreeze for water .
That idea got shot down in a big hurry , got my head bit off . Two wheel of four ...spilled antifreeze sucks . That corner is junk for the day .
Old 08-30-2010, 03:27 PM
Joe_Planet
Joe_Planet's Avatar
Can someone educate me why the antifreze is bad vs water
Old 08-30-2010, 03:47 PM
Falcon
Falcon's Avatar
A/F is very slippery, and not quickly visible by the corner workers or the cars following along behind.
It does not evaporate like water, so it has to be cleaned up by track personnel.
Old 08-30-2010, 03:51 PM
SIK02SS
SIK02SS's Avatar
ever stepped on armor all on concrete or asphalt?
anti-freeze on track is like putting oil or armor all on the ground: it makes it VERY slippery to drive over; whereas water doesn't "coat" the ground, it just absorbs in and evaporates.
Old 08-30-2010, 04:09 PM
donymo
donymo's Avatar
Default great idea, but...
I agree that a "no antifreeze" policy would be good.
But, there is NO WAY track clubs would be able to run HPDE events with a requirement of no antifreeze.
Old 08-30-2010, 04:32 PM
0Randy@DRM
Former Vendor
Randy@DRM's Avatar
It takes about ten minutes to swap out antifreeze. I don't see why it would be a issue. Send a email to people signed up for the event. One guy in tech taste testing the water. Done, no more antifreeze.
Randy
Old 08-30-2010, 04:37 PM
1991Z07
1991Z07's Avatar
Randy
I run distilled water and Water Wetter in mine when I go to the track.
Never had an overheat problem yet...and that's in Texas heat.
Old 08-30-2010, 04:43 PM
Jason
Jason's Avatar
CI 4-5-6-7 Veteran
I got a few people I'd like to nominate for this job.
Old 08-30-2010, 04:56 PM
AlwaysInBoost
AlwaysInBoost's Avatar
Randy
it takes WAY more than 10 minutes to swap anti-freeze out. You 'might' be able to drain the radiator in 10 minutes, but to fully drain the block and make sure ALL the anti-freeze is flushed out will take a lot longer... maybe a whole lot longer depending on the car. I agree its a safety issue, but honestly I've seen more people lose their motor and oil a track down compared to losing the anti-freeze.
Old 08-30-2010, 05:26 PM
AU N EGL
AU N EGL's Avatar
Advance level DE students should have water anyway
Old 08-30-2010, 05:33 PM
SouthernSon
Support Corvetteforum!
SouthernSon's Avatar
Location: Deal's Gap 2004 NCM Motorsports track supporter
Received 1,103 Likes on 717 Posts
Agreed, no way in hades the average new student would consider the extra effort. If one wants to run with no A/F, it will have to be sanctioned events only. That is the world in which we live.
Old 08-30-2010, 06:11 PM
dvandentop
dvandentop's Avatar
yep distilled and water wetter here. also. would like to think i am not alone of this especially at some of the speeds we see and the high speed braking
Old 08-30-2010, 06:30 PM
96CollectorSport
96CollectorSport's Avatar
Location: If you don't weigh in you don't wrestle Road America
Randy
They'll never be able to keep an eye on this for HPDE's! Racing and TT is another thing, but for HPDE it just isn't going to happen.
Plus how would you suggest checking for antifreeze in a car that the guy got up to running temp waiting in line?
Here's my day in Tech, burned my hand on 30 different radiator caps, scaled 10 times and burnt my tongue tasting anti-freeze (can't be good for you btw). Your only hope is that the field is filled with old VW bugs and air-cooled 911's!
Old 08-30-2010, 07:52 PM
John Shiels
John Shiels's Avatar
Location: Buy USA products! Check the label! Employ Americans
Discount entry fee for people who don't run anti-freeze
Old 08-30-2010, 08:10 PM
CorvetteZ51Racer
CorvetteZ51Racer's Avatar
Most clubs in Texas require a tech inspection to be filled out and signed by an ASE certified mechanic or a race shop within 30 days of the event. While this isn't a flawless way to check, it is a huge step in the right direction. Do you think someone is going to go through the effort to make sure their car doesn't have AF in it for inspection and then swap it out afterwards before the event?
The only way I see a problem enforcing this is during the colder months of the year (or month, in my case).
To Running Anti-freeze on track.....
Old 08-30-2010, 10:38 PM
SouthernSon
I am all in for the safety sake of using plain water. Notwithstanding my lack of any quantifiable data, I feel that the economy has adversely affected attendee numbers at HPDE's and that track day promoters just don't need any more knocks against putting together a full event. I view it as accept the status quo or plan on not so many events in the future. Could be wrong but I don't think so. Actually, I understand there are several track start ups that are not going to be completed or are running way behind on opening. If it is not profitable, it won't happen.
Old 08-30-2010, 10:43 PM
0Randy@DRM
Former Vendor
Randy@DRM's Avatar
OK ok ok. Maybe it's not going to happen in my perfect world
Randy
Old 08-30-2010, 10:45 PM
0Randy@DRM
Former Vendor
Randy@DRM's Avatar
Yea but it's faster then fixing broken cars is all.
Randy
Quick Reply: Running Anti-freeze on track.....
