C4 harness bar
Old 09-05-2010, 07:22 PM
kimmer
kimmer's Avatar
C4 of the Year Finalist
Default C4 harness bar
Does anyone have a Hardbar harness bar, and if so how do you like it. How was installation and was everything you needed for install included? Thanks, Kim.
Old 09-05-2010, 10:25 PM
Z06-Nomad
Z06-Nomad's Avatar
I just spent 2 days installing a Hardbar in a C5. It was a nightmare. The bolts that they send you are too long. They will reach the end of the stock seat belt mount holes and then start deforming at the tip because there are no more threads back there. By the time you figure something is not right,
and reverse the bolt out, that deformed tip is destroying the good threads on the way out. I ended up having to buy a tap to fix the threads of the
B pillar, Then bought a grinder, a vise, an electric saw (hacksaw would have added another day) and had to fabricate a spacer to put on the head of the bolt so it would be the right length.
The Bar itself is a work of art, but the hardware they send you should be labeled "B pillar destruction kit"
MD
Old 09-06-2010, 01:54 PM
kimmer
kimmer's Avatar
Well, that's not good.
Old 09-06-2010, 02:28 PM
0Paul Ruggeri
Former Vendor
Paul Ruggeri's Avatar
I've had one in my 86 for years. I recommend getting the extensions so its not right behind your head. I had no problems installing it and having a real harness holding you in the seat makes a big difference driving on the track.
Old 09-06-2010, 03:36 PM
BrianCunningham
BrianCunningham's Avatar
Location: Boston, Dallas, Detroit, SoCal, back to Boston MA
Mine's been in the car for almost 10 years now
Really stiffened the car up
Old 09-08-2010, 01:51 AM
MarkBychowski
MarkBychowski's Avatar
I have one in my '96. None of the problems the above poster had with the C5 but could be that the installations are significantly different. Hardware was high quality and installation was pretty easy. Installed mine about 8 years ago.
Old 09-08-2010, 08:18 AM
blakngold4life
blakngold4life's Avatar
I hate to take this off topic, I have been trying to find out if it is alright to run a harness bar and harness with stock seats, which I see you have. Have you had any problems with the shoulder straps slipping or not being allowed to participate in events due to them not going through the seat backs?
Old 09-08-2010, 09:46 AM
Aardwolf
Aardwolf's Avatar
More and more clubs are not allowing a harness to be used unless the shoulder belts pass through the seat.
Old 09-09-2010, 08:16 PM
BrianCunningham
No problems so far.
Old 09-09-2010, 10:24 PM
USAsOnlyWay
USAsOnlyWay's Avatar
It annoys the hell out of me using my shoulder harnesses off of my cage without them passing through the seat. They'll fall to the side of the seat sometimes when I take them off and I know they should be better centered in line with my shoulders.
I think Kirkeys will be in my c4 sooner or later, for better or worse...
To C4 harness bar
Quick Reply: C4 harness bar
