Kumho XS 315/30/18 Rear - Any issues?
Like the title states, who runs the Kumho XS in 315/30/18 in the rear on a C5 or C5Z?
-Do the brakes lines clear ok?
-How about the rear brake duct and fender?
-What front tires are you running?
Thanks in advance!
Thanks in advance!
Anybody use these XS for street driving on a C5 Z06 or C6 Z06? I would be curious for feedback, as well as if anyone has any opinions on their suitability as an "intermediate" rain tire.
I have been running them on my C6 Z51 procharger Vette for a year and love them for street driving and the track..as far as driving them on the street in rain I have had no issues whatsoever...great tire..
Dave G.
Received 1,722 Likes
2023 C5 of the Year Finalist - Modified
St. Jude Donor '09-'10-'11
I have not tested the XS but I have tried a few different tires. The best one for all the categories listed is by far the Goodyear GS-D3. Dry grip is great, you get lots of street miles out of them, and it is by far the best street tire I have ever driven in the rain. Wet traction is outstanding! It is a great all around tire for street/trackdays/rain.
I just did nine laps at the Milwaukee Mile road course in the rain . Just as good as the 6 year old all season tires I had on before .17/275s
I've seen the XS tire used for autocross and works well in that environ. No idea about wet conditions.
HTH, and have a good one,
Mike
I have been running them on my C6 Z51 Vette for two years and love them for street driving and the track..as far as driving them on the street in rain I have had no issues whatsoever...great tire..
Am I correct that the abs functions properly regardless of tire size?
Dave G.
ABS probably (?) uses individual wheel speed sensors to do its job. TC compares F:R wheel speeds... with the smaller rear OD it'll look like the rears are turning faster than the fronts -- like they're spinning. I'm not sure if AH even considers wheel speeds...
If I understand correctly, the TC/AH may get a bit upset by this combo, but the abs should function just fine. The car only sees the street about 10% of the time that I am in it so I am not too concerned. i really only need the abs to function properly for track use.
tc/ah will be fine with this. I have run it. Also 295f/315r.
You are correct.
I ran XSs for two seasons - when tread is < 4/32, they will plane out over any amount of standing water at highway speeds. Be careful...
295/35r17 is listed at 25.1". 275/40r17 is listed at 25.7". 315/30r18 is still 25.5" according to TireRack. So the 295mm tire should be fine, the 275mm, though, is taller than the 315... or am I misinterpreting and you're saying you've successfully run the taller front tire? (And what year car?)
On my 04 c5z I have run
stock
255/295
a6's
275/315
295/315
710's
275/315
295/315
aspect ratios vary with the brands.
There is a "tolerance" built into the wheel speed computing for tc/ah.
plus/minus a certain rotation speed does NOT trigger an incident requesting tc/ah to intervene.
In my personal experience all the above are within the tolerance spec & do not cause tc/ah to intervene.
FWIW
I forgot:
315 on 18's all around
Grand Sport (coupe) rims with appropriate tires (I forget sizes) 17 inch x 9.5 and 17 inch x 11.0 all no problems.
Plus some Yoko slicks off a GT3 no prob.
stock
255/295
a6's
275/315
295/315
710's
275/315
295/315
FWIW
I forgot:
I almost bought 285/17 s but the dimensions on the Khumo site said they were the same size except the 285 s were 4 # heavier .
Any thoughts ? Typo on the site ?
I did not shave mine ( tires ) btw
