Tire trailer pics?
Tire trailer pics?
Anyone have some pics of their tire trailers that they'd like to share? Looking for something that will accommodate 8 wheels w/tires on a 40x48" trailer. I've seen this setup at a few auto-xs, but didn't have a camera with me.
Thanks.
Thanks.
Thanks - the 8 wheel setups I've seen have 2 horizontal rows. I need to know how much & what size tubing to buy to weld up the wheel holders.
On that setup you had to separately buy the little wheel/support (proper name?) near the hitch?
Also - anyone have a wiring guide?
Thanks.
Thanks.
Thanks.
Thanks.
I don't think I've ever seen a 40 x 48 trailer setup for 8 tires. I've seen several with 4 tires in a single horizontal row. I'm sure that two rows of 4 tires each will fit onto the 40 x 48, and they won't exceed the maximum weight capacity either. I think you will have to do some of the design work yourself, though.
One thing I learned the hard way with my trailer is that you need to position the overall load a little forward of center, so there is a little steady-state weight on the tongue of the trailer. You could either build the framework for the tires a couple inches forward of center overall, or always load the heavier tires on the front part of the trailer.
If the above picture is a Harbor Freight trailer (looks like it is), then the little wheel support, the spare tire, and the spare tire mounting are extra cost options that you can get from Harbor Freight.
The wiring diagram for the lights on the trailer comes with the trailer when you buy it from Harbor Freight. The easiest and best way to do the hitch wiring in your car is to take the car to a U-Haul Trailer rental yard, and ask them to install the wiring. It will take less time and be a better installation than you could do yourself, and it should cost less than $50.
Tractor and Supply trailer 5X8 holds 8 tires plus big tool chest. Cost about $350, Hitch another $150, plus another $150 install. I did the wiring myself when moving to second car, was really easy. I've done many 4 hour trips to the track and back. I just leave it in the paddock at night (next to a Ferrari or 28' rig ). It works real good, but I really dont like feeling the clunking on my baby. I think the drive to the track stresses me more than the actual track day. That could just be my inexperience of pulling stuff though.
I've got way over 5,000 miles on my tire trailer now, and the trailer, the hitch, and the car are still OK.
Here is my harbour freight trailer, I use wheel chocks from walmart bolted to the plywood and strap them down to eye hooks I've installed in the trailer frame. I can haul 8 tires. A couple of buddies have this setup too and we've never had any trouble.
This is my friend's modified Harbor Freight 4'x4' trailer. We bolted the tool box to the front and then strap two sets of wheels behind it. While it was originally 4'x4', we extended it to 4'x6' and moved the axle back to be able to fit both sets of wheels. It works well for us but we run 245/40-17 Hoosiers on the track so they're not all that wide. If you're using it for Corvette sized tires, they will be too wide. If HF makes one that's 5' wide, that would probably work.
We tried laying the tires down in stacks but found that standing them up and strapping them down was held them down the tightest. With two straps through each set, one going forward and one backward, they don't move a bit. (Those are our street wheels in the picture so they aren't strapped down correctly. I couldn't find a picture of the trailer loaded up and tightened down the right way.)
We've been using this trailer since ~2004 and it's worked out great. We've towed to Watkins Glen, MidOhio, and a few tracks here in Michigan. Other than one incident where it fell off the hitch in rush hour traffic in Buffalo, it's been solid. As mentioned above though, it doesn't handle concrete roads very well and we usually have to slow down to around 70 to keep it from jumping around due to the expansion joints.
No pictures handy. But I have the same trailer as Kwhiteside. The Tractor Supply 4' x 6' trailer. It is actually made by Carry On. They make all types of trailers. This trailer is welded with a proper framing and can handle the full Class I load in case you need to use it for other things. I've put my riding mower and stuff on it.
That extra size is enough so that I have my Contico bin in front. Then stack 2 tires flat on each other in the middle then 2 the same in the rear. It balances out the trailer nicely. It also makes room to put a canopy, folding chairs, cooler, gas can, whatever. If I need to bring 6 tires then 3 standing up side by side like in the picture above. No need to weld or bolt pipes on it. Just have a dozen tie down straps and it all locks in place and works.
Great trailer for the money. Mine might actually be for sale since I just bought an 18' open deck hauler :-)
Cruising
Tire Trailer
Here is my variation on the tire trailer - pulls great and you hardly notice it's back there
[URL="http://s1193.photobucket.com/albums/aa353/jchvmsc/Tire%20Trailer/?action=view¤t=TrailerClose1.jpg"]
[URL="http://s1193.photobucket.com/albums/aa353/jchvmsc/Tire%20Trailer/?action=view¤t=TrailerClose3.jpg"]
This is a Northern Tool version that I had to do a lot of mods to to get it where I wanted it. Added LED lights and larger tires, spare, toolbox and box for the tires
JCHVMSC
JCHVMSC
Here's mine(Harbor Freight) but it only holds 4 tires. I lengthened the tongue by 18" to smooth the ride and it makes it easier to back up.
http://i57.photobucket.com/albums/g2...3/100_1333.jpg
Found mine on craigs list 150 + about 60 other in parts .... have towed at Interstate highway speeds with no problems at all .... Box is from walmart I also strap the orange cooler to the fender with a net type strap ...
St. Jude Donor '10
I have a small Harbor Freight trailer that I modified to fit my needs and wants. I added LED tail lights and upgraded to the larger 12" tire size. If I could do it again, I would have found a 5 lug bolt pattern trailer wheel, so I could increase the tire size. I have four stock size C5 Z05 wheels on the trailer, plus a big tool box and a spare trailer tire.
I am in the midst of upgrading the set up. I added a tire cradle instead of laying them flat. I use a galvanized pipe and PVC pipe on top of that, to secure the wheels in the new position, as opposed what is pictured.
I had the entire trailer "Beefed Up" with additional welds after adding the cradle and a friend is painting the whole trailer LeMans Blue!
ORIGINAL SET UP
NEW SET UP BEFORE FINAL PAINT
ORIGINAL SET UP
