TPMS trouble at SCCA Nationals, Please read!
I have a friend running Super Stock with a C6Z. He's been running the car without the TPMS sensor with no problems until now. The battery was dead yesterday. After getting the car restarted, the car now won't allow him to turn off AH.
What can be done on-site to fix this? Can we borrow a set of wheels/tires with sensors to trick it in to working again? Is there a way to do this without a calibration tool?
Is there a way to temporarily trick the car in to turning all the nannies off? I've read a couple of posts suggesting this by turning off the car, restarting, then clearing all messages. (we haven't tried this yet, still at the hotel this morning)
Thanks,
Dave G.
Thanks,
Dave G.
Can't "trick" the ECU. You will probably need a set of sensors and a tool to learn them to the ECU. Or, you will need the original sensors, installed in a pressurized tube (or wheels) so the ECU can see them.
Nearby dealer is the best shot unless you can find someone at the tack with the tool.
Received 2,051 Likes
St. Jude Donor '13
Received 8,928 Likes
Check with another competitor to see if they have wheels with sensors and happen to have a TPMS training tool. If the person will let your friend borrow the wheels for a half hour or so take them and place them next to the car and use the tool to train the car to the competitors wheels. Once that is done the car will think it has TPMS sensors installed. Then return the wheels and tool to the new best friend.
I don't know how far the sensors transmitters can reach but he could try parking next to the guys car with the left side next to the right side and training the the two on that side and then moving the other guys car so the other sides of the cars are next to each other and then training the last two sensors. If it works that could save some time.
Bill
Bill
This is the fix (if you don't have sensors). A low battery on a C6Z causes havoc. My windows wouldn't index properly, TH wouldn't release, sometimes the windows won't work all together. A low battery on a C6Z will cause tremendous electrical issues. It sounds crazy, but it is 100% true.
Location: Deal's Gap 2004 NCM Motorsports track supporter
Received 1,103 Likes
Not a C6 guy but could this be one of those deals where one has to drive the car a few miles/and turn off and on a few times for everything to reset correctly. I know there are some things that do require the vehicle to be driven several miles after clearing the problem.
I had a similar issue where the ECU on my C6Z wouldn't let me turn the nannies off during an HPDE. Didn't have a low battery, but it started happening as soon as the TPMS diagnostic popped up (my track wheels didn't have TPMS in them). Unfortunately, I was driving the car hard enough at the track that I overheated the brakes due to the AH and a 105 degree day. When I mounted the new set of tires (the old set was polished off when I slid off track at 140), I put TPMS in them. A guy at the track had the reset tool, and I didn't have an issue the next day with the AH.
Just a reminder on the C6, when you park it, especially if the battery is known to be getting tired, put it in reverse when you turn it off. This will let the different electronic modules in the car go to sleep. If you don't, they will slowly drain the battery (on a strong battery, it will take weeks, but I've heard of it happening much faster on a weak battery).
Tricking the car by placing a set of wheels with sensors will work. You need to pair the other wheels to your car with the reset tool, only thing is you will not get a too many laps before the car will sense no air pressure info being sent to the computer and put you back in fault mode. In any event once you shut off the car it will go back into fault mode anyway. I have spent a few days playing that game at the track and it gets old fast.
I have also found out the following, I start off the day all sensors working in my track wheels and all is fine, then at some point one sensor will stop working, a few laps later car will go into fault. I will return and find that the faulty sensor will not reset with the tool as if it has just gone bad, I tap with a wrench rather hard on the valve stem a number of times and then the sensor will start working. we tried this with a friends Z that was having the same problem and his sensor started to work again.
