Corvette family CMP
Corvette family CMP
Big thanks to Pat (Silver Z06) and Billy (burgundy C5) at CMP this weekend..... Along with my bolt issue I had my clutch master decide to kick the bucket .... Billy was more than willing to lend a hand in replacement and Pat even gave me a bolt from his own car..... Good to have people wiling to lend a hand when things are not going your way :-) Will pay it forward someday I am sure.
I'm planning on running there (HPDE) for the second time on Oct. 15th. Nice place.
Do you have any brake modifications and how did your brakes hold up there?
My first time down, last Spring, it was raining a bit so I never got a chance to go full out. I have little confidence in my stock braking system (though I am running Motul brake fluid) and was curious what your experience was like.
Thanks!
Thanks!
Thanks!
Thanks!
I will put a video up soon...
After the kink, T14, and T1 (all in a row) you have the park the car from 100+ mph.
1:43-1:44 last year with a "street" stock TTA car.
sperkins did a 1:42.xx this year in his stock black 03 with a street alignment and C91s
best lap this year with a better "prepped" TTA car, 1:40.2.
275 Hoosiers/C91s
275 Hoosiers/C91s
I have ran 3 times at CMP .... I am run in the Solo groups and run. about 1.55 - 2.00 minute laps. I do short shift and am not full out on the straights running PFC01 have had no problems with the brakes .... I can usually get 3-4 days out of pads... I use ATE blue / gold fluid with no additional cooling on the brakes ... this is with stock size NT05 tires..
I lied. I'm running the same Blue brake fluid you are. My best lap was around 2:00 short shifting and not going WOT (accelerating and braking at about 80%) but working the turns at about 100%.
My front tires at the time were pushing pretty bad. Hoping the replacements will cure that problem.
A friend in his stock C6 ZO6 running Hoosiers was running mid to low 1:40s. His dad was in the low 1:40s and is a former instructor there.
In a full weight (3306lbs), stock 03Z06 with an aggressive alignment and lowered ~1 inch, I ran a 1:43.xx on fresh 275 Hoosier A6s in 100+ degree heat in June this year. The track was greasy as hell.
Not the 1:40 barn-burner Mark ran, but I do believe he had temps in the 60s or so (early May I think). Or maybe I am saying that to make myself feel better, LOL.
At CMP, on a hard weekend, I can go through a set of Carbotech XP12/XP10 pads in two days.
-Kevin
-Kevin
Mark did not see any temps near the 60's. It was slick out. But, back on subject, you may wear the pads out or crack a rotor, but the brakes will stop you when asked.
-Kevin
-Kevin
CMP is weird, the grip either sucks, or really sucks
I always figured it was the sand, but when we walked the track in May, the surface was actually very clean.
The run in May was first timed AM on Saturday, maybe 75-80 by then? I had sticker rears and scrub fronts and literally couldn't turn the car the whole lap. I'd say there was a second left with sticker fronts.
Me and scott went at it hard in Nov and Feb, both when it was cool, and never ran quicker. Almost like when you make more power you just can't hook up and go slower.
I go back and forth on hating/not hating that track. I'd feel better if we bulk mailed all our brake pad backing plates to Alan Wilson
735 E Mont Clair Drive
North Salt Lake, UT
84054
North Salt Lake, UT
84054
Morris, thanks for making me feel worse.
I don't like CMP, simply put. I go there because my friends do events there and it is less than 2 hours away. It is hard on brakes and hard on tires. This past June was the first time I have been there in several years and didn't cord a tire. Mainly due to the fact that I had paper thin brake pads and didn't want to put on another set so I nursed the car except in TTs.
With that said, I will be driving an endurance race there (LeMons) two weekends from now, LOL. I'll run anywhere anyone lets me; pavement, dirt, ice. I don't care!
-Kevin
-Kevin
YES! Bring on the video!!!
Here is a video of me in the pewter vette that is my avator . I do not have lap times in it but I have ran a 1:46 in a stock c6 with spent hoosiers . I am not the biggest fan of cmp but I also only go because of my freinds and I instruct with the Carolina's Region PCA and this is our home track.
-Kevin
-Kevin
What are you going to be driving. I will be there driving the batmobile saturn.
1:42.118
1:42.248
1:42.891
1:42.348
http://www.youtube.com/watch?v=XiS0bhEvt14
Car sounded great! Thanks for posting.
Found my best lap at 1:52 through 3 events there ... but def consistent in the 1:57 range... need to really try and bust tail and see what I can get it to .... guess then I will eat up more pads :-)
I put on my rear 285 nitto RIIs (decent shape) and scotts 275 RIIs (totally shot) in may and flogged it as hard as I could and did a 1:47 something. understeering pig with those trashed R2's up front
shows you what tires are worth
