Outer Tie Rod Boot?
Outer Tie Rod Boot?
Noticed this the other day when changing brake pads. Is it a tie rod boot that has melted? Do I just need to replace the boot? I am headed to the track this weekend, so I want to figure out what exactly I need to replace.
Try to shake your wheel side to side and see if there is any play in the tie rod. If the wheel moves side to side a little, but not up and down then your tie rod is going bad and should be replaced. They aren't too expensive so I would just get a new tie rod instead of a new boot unless the tie rod was fairly new. Based on the picture, I would say get a new one .
Received 8,919 Likes
I use header wrap on the boots and then made some shields out of soup cans that shield the boots and wrap from the heat radiated from the rotor.
Bill
Bill
