Anyone running new vette (08-10) at track with R compound tires.
I wanted to know if you are useing non-stock wheel sizes with R compound tires and having no issues with electronics (abs), Stability control, traction control. Tire rack told me that the newer vette can't shut off or defeat the system so you can't run differ wheel or tire sizes or it will mess with the electronics. I looking to run 18's all-around and they had no clue what to do and told me with the last few year vette it will create a problem..you also need the TPS intact for the car to run normal..anyone with experience please help me out..
I have a 09 vette C6 Z51
PS there is NOT r compound tire that I know of that you can run with stock wheels..
I've got an '06, so ...
From what I've heard, your rear tire diameter needs to be larger than the fronts. Otherwise the AH & TC will not like it. I don't know exactly how the AH & TC react though.
My experience with my '06 is:
- I can shut off the AH & TC by holding down the button for about 5 seconds. Try this on your '09 to see if it will shut off.
- The ABS is still negatively affected when the tire-diameter-ratio is incorrect. For awhile (not now), I had slightly larger tires in front than in back, and the front tires skidded more often than they should (ABS didn't engage as often as it should).
I think the AH & TC on your '09 will be OK, if you ensure your rear tires are a little larger than the fronts.
ABS should not be an issue.
Tim
Like I mentioned in another thread that Trapp started, I'm running 18" wheels all around, but I made sure that my tire diameters are a little bigger in the back vs the front.
Well I understand your comments but your not completely aware of the issue with the newer C6 models..Even tirerack knows that you CAN NOT defeat the AH/TC completely even if it is shut off completely. Somehow the ECU nows if the diameter of the tires are with spec even with it shut off. I know this because we had a 09 vette at the track that put on 18' wheels with R compound and the car was acting very scary on the track engaging and disengaging the AH inappropiately with the "system completely shut off" After stock wheel and tires put back on ..all was well. Tirerack told me to find someone with a 08-09 vette that is running R-compound and match there wheel and tires....so far I haven't found anyone yet..
I will have to get custom wheel and tires that match my stock tire diameter front and back....
Received 8,928 Likes
I know a couple of people running 18 inch wheels all around on C6Zs. However, they use different size tires front and rear with the larger diameter tire being in the rear. They have no issues when they turn off the AH and TC. It looks like the C6Z hot wheel setup is a CCW 18x11 in front with an 18x13 in the rear.
There are also some people running R compound tires on stock wheels. The reason people go to the 18s is cost and availability of tire take offs from racers. Hoosier makes exact size R compound tires for the C6Z and Kumho makes tires that will fit. For the regular C6 tires Hoosier can give you an exact match for the front and the next size up for the rear. Kumho can match the stock front size but not the rear. By the way this is from the Tire Rack web site.
Bill
Bill
Here's my setup ... and so far, it "works" :
2010 C6 Coupe, not a Z51 or Z06:
I'm running 17 x 9.5 C5Z wheels on all 4 corners, w/ 275/40/17 NT01's (minor issue, the inside of the front rims catch the tie-rod jamb nut while turning full lock!).
... anyway, I have NO TPMS, and the tire heights are all identical (not staggered).
I shut EVERYTHING OFF (TC & AH OFF) and have run 5 track days so far, with NO PROBLEMS whatsoever. 2 of those 5 days have been in the rain, and I HAVE engaged ABS, and still NO PROBLEMS.
When the car first starts, I get the error message "Service TPMS system" (or something to that effect). The "check engine" light (I think that's which light it is?) flashes, and while it's still flashing (during the first ~20 - 30 seconds of the car starting) I push and hold the TC/AH button for ~5 seconds, and get the message "TC/AH system OFF" (at which point, there is another light on the dash indicating the TC/AH off).
Point being, I've run 5 days (2 rainy) on 3 tracks, and had no problem with the car .
However, I've heard that 2010's may be different than all previous years? (at least the TPMS are different ... they can be calibrated to the car by adjusting the air pressure up/down, without the use of a tool as in previous model years). Not sure if the TC/AH system itself is any different though?
But in the meantime, it's working for me (although I wish I had wider wheels/tires all around :o ).
I have an '08 Z51 that I run 18" x 10.5" C5Z06 rears on all 4 corners with the same size tire (305/645R18 Hoosier R100's) on all 4 corners and no TPM's. I run with all nannies off. Sometimes I get a Service Active Handling message when sliding all 4 tires thru a mid speed left hand turn but no interuption in the handling of the car at anytime. Otherwise it works for me.
changing wheel sizes
This is my third year w/ NASA HPDE events. First year I ran run flats. Last year and this, I ran street tires and now am hoping for a DOT tire.
I looked into the selection our local Hoosier dealer offers and could not quickly locate the size you are using. How much money is each tire running? Have these been easy to order? Are these DOT? I think it will be a while before I seriously consider big brakes, but am wondering if there is there enough room for you to add big brakes under these wheels ?
I too have an '08 M C6 that I track and have been looking at other options for tires. Interesting change you made going to 18" x 10.5ea" C5Z06 all the way around. I may want to seriously consider this. I run w/ the AH/TC off, so going w/ different sizes may not be that big of deal for my computer.
Received 3,805 Likes
"Ask Tadge" Producer
Inside joke with our little track rat crew. It started with the IHD club, which stands for "I Hate Dan". Dan has a funny way of making us all spend money on stuff we really don't need. Therefore we hate him.
Dan decided to deflect that hatred to another member of our club. So far, no one else has taken the bait. :-)
jas
jas
