Filling Transmission with fluid
I'm replacing tranmission fluid on my C5Z which has a cooler on it and I was told it should hold 6-8 quarts in it. I got about 3 quarts and it started coming out of the fill hole. Am I doing something wrong?
Does it have an electric pump and did you exercise it with the drain plugs open? If not you only drained what was in the tranny and didn't drain the cooler. Some systems you have to open the cooler lines and drain it before refilling...
Talk to the person that installed the system and get the proper draining and filling procedure or you are likely only doing the job half way each time...
It all depends on the location of the cooler in relation to the transmission. If it is lower than the tranny, you will not get a gravity drain on it by just removing the tranny drain plug. You might have to remove the lower oil line to the cooler and drain cooler and its lines from there as well as use the drain plug. When you fill, run the pump for a short time to refill the cooler and lines, then check the fluid level in trans again and add accordingly.
Aaron
I just did mine yesterday and thats how I did it. I also put the air hose in the tranny and blew everything out including the cooler lines. Filled it till dribble, then reconnect line and run pump for 2 minutes and then recheck level and had to add another 1/2 quart.
Aaron
Aaron
