2 piece rotor question
Old 10-05-2010, 09:16 PM
Joy of 6
Joy of 6's Avatar
Default 2 piece rotor question
I have a set of 2 piece rotors coming. They will last much longer than than NAPA's. What other benefits have you racers found from these. Does it affect fade?, pad wear?, will they dissipate heat better?
thanks
Old 10-05-2010, 09:27 PM
geerookie
geerookie's Avatar
thanks
They reduce the weight of the car.
Unsprung weight at the wheels and sprung weight at the wallet.
The quality of the materials of the ring and how many vanes are in the ring will have the the most to do with how long they last and what their thermal capacity is.
Fade and pad wear are all up to the pads you use.
Old 10-05-2010, 09:35 PM
WNeal
Support Corvetteforum!
WNeal's Avatar
Cruise-In Veteran VII
Cruise-In Veteran VIII
"Slower Azz Dog"
St. Jude Donor '06-'07-'08-'09
Is there ANYTHING cheap in this sport?
Old 10-05-2010, 09:44 PM
John Shiels
John Shiels's Avatar
Location: Buy USA products! Check the label! Employ Americans
air in tires?
Some two piece rotors are heavier than OEM GM
slotted feels better to me for less fade.
how they last depends on what they are made of and how they mount to the hat.
Old 10-05-2010, 09:56 PM
geerookie
geerookie's Avatar
Me???
Old 10-05-2010, 10:50 PM
RX-Ben
RX-Ben's Avatar
Originally Posted by John Shiels
air in tires?
Sounds like you haven't started carting around nitrogen.
Old 10-06-2010, 05:41 AM
John Shiels
I have a tank outside. It is cheap too as this sport goes.
To 2 piece rotor question
Quick Reply: 2 piece rotor question
