What do you do with worn parts?
Old 10-12-2010, 11:58 PM
PCMusicGuy
PCMusicGuy's Avatar
Default What do you do with worn parts?
Like the title says, I'm wondering what you guys do with old or worn racing parts, like brake rotors, bearings, shocks, etc. I'm thinking about building a coat rack for work with a motörhead theme and I was wondering if old parts are recycled or discarded. Perhaps I can check for scraps at some local speed shops.
Old 10-13-2010, 05:42 AM
John Shiels
John Shiels's Avatar
Location: Buy USA products! Check the label! Employ Americans
round file!
Old 10-13-2010, 07:13 AM
SouthernSon
Support Corvetteforum!
SouthernSon's Avatar
Location: Deal's Gap 2004 NCM Motorsports track supporter
Received 1,103 Likes on 717 Posts
I'm considering making a 2 ton rolling press with all my cracked rotors.
Old 10-13-2010, 07:18 AM
AU N EGL
AU N EGL's Avatar
Cracked rotors ? keep your body wt in old rotors. Great for corner balancing your car
or a pathway in the yard. recycle them once a year. 20 cents a pound for scrap iron ?
Old 10-13-2010, 09:20 AM
varkwso
varkwso's Avatar
I use cracked rotors to patch potholes in my driveway.
I hoard all the other used parts - three wore out torque tubes at last count, calipers, brackets, blown up LS1s/LS6s, several diffs, trans, switches, interior bits, excess engine stuff, scuffed body parts, and almost everything else that comes off. I use about 1% but it is a disease I hear. I never ever toss a bolt from a C5/6 unless it is bad...
Old 10-13-2010, 11:36 AM
Solofast
Solofast's Avatar
That's just sick... BTW does anybody need the behind the seat plastic bins from a C4....
As the saying goes, "you can't argue with a sick mind"....
Old 10-13-2010, 04:33 PM
flink
flink's Avatar
It's best to replace parts before they break! If I'm preventively maintaining bearings, hubs, studs, cooling system parts etc then I'll toss the old part in the trailer - it still has life in it and might get me or a pal out of a fix at the track.
Old 10-15-2010, 02:23 PM
Painrace
Painrace's Avatar
TRASH!
Jim
Old 10-15-2010, 02:42 PM
varkwso
varkwso's Avatar
Originally Posted by Painrace
TRASH!
Jim
You must not be an engineer or scientist.
They keep everything!
Glad I kept the fuelie units and 2x4 intakes I took off for aftermarket intakes and Holleys back in the 70s.
Old 10-15-2010, 02:58 PM
John Shiels
Will we see you on that hording show anytime soon?
I keep all the stuff I removed form the car during it's transition as I could not be bother to sell it or if I convert back at 90 and want visors, rugs and all the other crap.
Old 10-15-2010, 03:04 PM
varkwso
varkwso's Avatar
I hope not but my 64 Galaxy 427 exhaust manifolds are going on eBay soon. Pretty sure I will not need them!
Old 10-15-2010, 03:26 PM
Mike P
Mike P's Avatar
I make "Car Part Yard Art" and various presents for family and friends.....
Coil spring snake
Differential Turtle
Rocker arms make great animal heads.
Mike P
Old 10-15-2010, 09:13 PM
vettehardt
vettehardt's Avatar
I belonged to a car club at Purdue (the Purdue Automotive Performance Association). We got old parts from our cars and a shop down there. We then made trophies for our car show we put on durring the Purdue Grand Prix. Some are elaborate whith camshafts, gears, etc. while some are simple like an intake vavle stuck into a trophy base.
Old 10-15-2010, 09:32 PM
Painrace
Painrace's Avatar
Degreed engineer! I have wrecked cars where even the gas cap was useless! Old parts are just old parts. They are junk to me and I don't want to be responsible for someone using them and having problems.
Jim
Old 10-16-2010, 07:04 AM
varkwso
varkwso's Avatar
Jim
That is fair. I have cars that even the gas gap is useless - according to my wife anyway.
To What do you do with worn parts?
Quick Reply: What do you do with worn parts?
