Drive shaft coupler and torque tube
Old 10-13-2010, 12:54 PM
The Spark
The Spark's Avatar
Default Drive shaft coupler and torque tube
The front drive shaft coupler / bushing went out on my car and tore up the torque tube.
I have a torque tube from a 2000 that had 90,000 miles on it that I can use as a replacement. Problems????
I have a track only car and was thinking about going with solid couplers instead of the factory rubber. Reading some older posts it looks like the camp is split on using 1 rubber and 1 solid or using 2 solid couplers.
OR - go with carbon fiber drive shaft.
Also read something about early vs late model torque tubes.
HELP! My car is torn down and we're ordering parts to get it back together.
Old 10-13-2010, 01:16 PM
geerookie
geerookie's Avatar
The difference between a '97 - '00 TT and the '01 and newer is the size of the driveshaft and the couplers.
'97 - '00 - 53mm driveshaft and 10mm bolts in the couplers
'01 and newer - 63mm driveshaft and 12mm bolts in coupler
The newer couplers are also stronger.
Here's all the parts needed. The bearings and slinger ring are the same in both.
I rebuilt mine about 3 years ago. I replaced all the bearings and both couplers. I used factory replacements but bought them from BMW because they were cheaper. You need a slinger ring, 3 bearings and 2 couplers. And one Big A$$ pair of C-Clip pliers.
Slinger Ring - GM part number is 12456208 cost $4.42 from http://www.gmpartshouse.com/.
Bearings -
SKF 6007 2RSJEM SINGLE ROW BALL BRGS 1 $25.64
SKF 6008 2RSJEM SINGLE ROW BALL BRGS 2 $29.33
These are the bearing numbers on the original bearings I took out.
NSK 6007 DU need 1
NSK 6008 DU need 2
Drive Shaft Flex Joint part# K1020-31191
Description: 12mm Bolt
110 mm diameter : Uses (6) 12 x 1.5 x 58 bolt.
Trans Type: 5-Speed Vehicle: 1998 BMW 318ti
Engine - Chassis: M44 : E36
Drive Shaft Flex Joint part# K1020-46069
Description: 10mm Bolt
96 mm diameter : Uses (6) 10 x 50 bolt.
Trans Type: Automatic Vehicle: 1998 BMW 318ti
You can get a FEBI coupler or the Lemforder which is the OEM. I went with the FEBI.
Old 10-13-2010, 02:28 PM
0Anthony @ LGMotorsports
Former Vendor
Anthony @ LGMotorsports's Avatar
St. Jude Donor '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13
Some of the early cars had a bolt together torque tube, and the later cars were all one piece.
They did go to a larger bolt size in '01 to a 12mm from the 10mm of the early cars. Shaft size is slightly different as well.
We did a carbon shaft for two major reasons.
1. The carbon is much stiffer than the alum. and resists the nature to bend or twist. This kills any chance of the shaft bending or causing any major damage and vibration
2. In the event it would break, the carbon simply turns to cloth and doesn't try to cut the housing or the car in half.
On the couplers, there are different ways to go. For most we retain an OEM unit in the front and a solid in the rear. This takes up for any tolerance in the assembly and cusions the blow so to speak and any vibrations or noise. For hardcore race cars we now run it solid front and rear.
Old 10-13-2010, 04:25 PM
Han Solo
Han Solo's Avatar
I read a thread on here that said the bearings between early and late were slightly different. Double check that.
Old 10-13-2010, 04:29 PM
geerookie
geerookie's Avatar
I've rebuilt a few pre '01 and '01 and later torque tubes and so far they have all had the same bearings. I have one of each right now and they are the same bearings.
Having said that, I wouldn't be suprised if GM did something like that but I think it's unlikely.
Old 10-13-2010, 05:25 PM
The Spark
The Spark's Avatar
Is it worth trying find a newer torque tube or just use the one I have?
My car is making 430 RWHP.
The 2000 Coupe that I have the TT from was used only on the street and I doubt hot rodded much. It did have ~100,000 miles on it though. I figured it would be a good idea to rebuild it with new bearings, etc.
Old 10-13-2010, 05:31 PM
0Randy@DRM
Former Vendor
Randy@DRM's Avatar
Check to make sure the tube is straight. Other then that you should be able to rebuild yours. The later models are a bit beefier, and the better program. As said before.
Randy
Old 10-13-2010, 06:56 PM
RX-Ben
RX-Ben's Avatar
Slinger comes up as $6.98 at gmpartshouse - are you using a discount code? I'm curious as I have a sizable order to make.
GM Parts Direct looks to be the cheapest (5.58) but have negative customer service.
Parts Taxi is a touch more (6.23), but actually has customer service (and it is good).
Old 10-14-2010, 12:30 PM
The Spark
The Spark's Avatar
Gene Culley at gmpartshouse is a forum vendor and supporter and many try to use him.
Gene gives great customer service.
I've used gmpartsdirect before. I've heard they stick it to you on shipping. I've not experienced that. But Gene helps support us so I'm willing to pay a little more to support him.
If you have a sizeable order you might contact Gene and see about pricing. My $.02 worth of info.
Old 10-14-2010, 12:36 PM
The Spark
The Spark's Avatar
Thanks for the information guys. My 2000 TT looks really good. I will get the parts to rebuild it (thanks for the PNs geerookie).
I'll take your advice Anthony and get a solid rear coupler.
I'd like to go with the later model TT but looks like they are as much or more than the carbon fiber drive shaft for new. Couldn't find source for used but didn't try that hard.
The front coupler on my old drive shaft disentegrated. The flared part of the TT that attaches to the bell housing came off like it was cut with a knife - very smooth cut.
Old 10-14-2010, 01:44 PM
geerookie
geerookie's Avatar
I think my price may be a year or two old. I bought 6 of them so I haven't looked one up in awhile.
Parts Taxi is also a forum vendor and just down in Delaware I believe. Them or Gene are both great to deal with. Parts Direct is a pain
Old 10-14-2010, 01:54 PM
0Vector Vette
Former Vendor
Vector Vette's Avatar
If this is a track only car, then I would recomend you change both couplers. If you only change one, the other will eventually break. We have aluminum couplers that we make ourselves in stock, they are $250 for the set.
Robert Finlayson
Performance AFX Motorsports
815-254-2631
Old 10-14-2010, 04:42 PM
0PartsTaxi.com
Former Vendor
PartsTaxi.com's Avatar
Thanks for the mention guys I'd be glad to help anyone out that needs these.
Old 10-15-2010, 12:24 AM
Han Solo
Han Solo's Avatar
okay cool,
I was quoting another thread I read on this subject where a guy said the early had 3 different bearing and the late had 2.
http://forums.corvetteforum.com/1575581118-post49.html
When I did mine I got lucky and found a deal on a brand new assembly in the box so I just changed the whole thing.
Old 10-23-2010, 01:15 AM
0Mike Yeager@Eastcoast Performance
Former Vendor
Mike Yeager@Eastcoast Performance's Avatar
Default Hey guys, check our specials out.!!!
We have rebuilt and sold thousands of parts for Corvette Torque Tubes over the past 14 years...Take it from someone who knows corvettes & corvette performance parts...If its a street car at least install our truely German Rubber couplers in the front & rear of the propeller shaft...If you want to make your set-up as strong as possible without busting your walet then use one of our CNC'd Billet Aluminum BALANCED Couplers in the rear...LMK if I can help any of you guys...We have it all instock!!!
Hey guys, we just received our shipment of Brand New LS7 Clutch Kits, they are instock ready to ship the same day you order...We also have all the accessories to complete your clutch install...
LS7 Clutch Kit ....$425
Includeds Flywheel, Disc, Pressure Plate & Alignment Tool...
C5 Remote Clutch (One Man) Speed-Bleeder Kit $59.99 w/Clutch Purchase
C6 Remote Clutch (One Man) Speed-Bleeder Kit $69.99 w/Clutch Purchase
ARP Flywheel & Pressure Plate Bolts Both $49.99 w/Clutch Purchase
TORQUE TUBE ACCESSORIES...
Torque Tube Bearing Kit (3 Bearings) $99.99
10mm & 12mm CNC'd Billet Aluminum Torque Tube Couplers, The units we make are Truely BALANCED...!!!
ECPC Billet Aluminum Balanced 10mm Couplers $139.99 each
ECPC Billet Aluminum Balanced 12mm Couplers $145.99 each
(the good ones, these say Made In GERMANY)German 10mm Rubber Couplers $79.99
(the good ones, these say Made In GERMANY)German 12mm Rubber Couplers $79.99
C5 Accessories....
C5 Z06 Clutch Master Unit $79.99
C5 Z06 Clutch Slave Unit $99.99
C5 Z06 Throw-Out Bearing (the good one) $39.99
LS1 & LS6 HD Pilot Bearing $12.99
C6 Accessories...
GM C6 Z06 Clutch Master Unit $129.99
GM C6 Z06 Clutch Slave Unit w/throw-out Bearing $189.99
LS2,3,7 HD Pilot Bearings $18.99
CARBON FIBER DRIVE SHAFTS on Special $899.99
We accept Visa, MasterCard, Disc, Amex, Paypal and Cashier Checks!!!
Old 02-28-2011, 12:01 PM
TDP
TDP's Avatar
I order them from bavauto.com to keep them in stock at my shop. The 1998 318ti BMW will pull up both types of bushings (10mm & 12mm).
26 11 1 227 410 110mm x 12mm $48.95ea
26 11 1 225 624 110mm x 10mm $44.95ea
They give free shipping if you order $150 or more, so I usually get 4 at a time. I've noticed that the OEM bushings and these BMW ones are identical. Both even have "made in Germany" on them. This leads me to believe that General Motors is simply using the same supplier as BMW. There is most likely only one manufacturing facility for this part and its in Germany.
I prefer these rubber "OEM" replacement bushings over the aftermarket. I had the poly bushing in my Vette that I had 5yrs ago. After only 6 months or so, the bushing had a crack by each bolt hole, going all the way thru. I also had the aluminum one in there. Not a good combo, as it yielded a vibration from 2200-2400RPMs. I went back to the rubber ones and never looked back.
Old 03-01-2011, 05:33 PM
LG Motorsports
Premium Supporting Vendor
LG Motorsports's Avatar
St. Jude Vendor Donor '03-'04-'05-'06-'07-'08-'09-'10-'11
We keep a good supply in stock/ the one on the left, with the scallops is the one we have been making for years.
The shavings are just for "effect"
http://www.lgmotorsports.com/catalog...b498958449d0ed
thanks
Lou G
__________________
LG Pro LT Headers, MOST HP, MOST TORQUE
http://lgmotorsports.com/gallery/alb...no_compare.jpg
LGM http://www.LGMotorsports.com
Winner Daytona 250
22 WC Wins
"Most powerful Corvette headers on the planet"
To Drive shaft coupler and torque tube
Old 03-06-2011, 01:04 AM
ColeTrain'sC5
ColeTrain'sC5's Avatar
Mike from ECP hooked me right up with these German rubber couplers and couldn't be happier with how it turned out so far. Great customer service. I hear great things about LG as well
Old 03-06-2011, 09:27 AM
ssdeuce
ssdeuce's Avatar
I'm thinking about doing this for PM but I would like to go with the solid ones would solid couplers take points away for TT? I'm also trying to think ahead
Thanks!
Old 03-09-2011, 12:48 PM
redtopz
redtopz's Avatar
Here's a picture of a newer propshaft vs. the older style:
Quick Reply: Drive shaft coupler and torque tube
