FS: C4 Koni shocks - double adjustable
Sold - C4 Koni shocks - double adjustable
Sold
These were Koni single adjustable sports that I had revalved and made into double adjustables by Koni NA. Used on my now gone 1989 C4 Corvette for SCCA Solo events, they won 3 national championships and a Pro Solo title since 2006. I believe these fit 89-96, should work fine on a BSP or road racing car. 2.5 sweeps of rebound adjustment on top and 12 clicks of compression adjustment below. Shock dyno graphs included with purchase.
$2080.00 plus freight if new from Koni. My price = $850 includes shipping to the lower 48 states.
How do you adjust the top, especially for the rear shocks since they are hidden up in the frame rails when installed?
Koni supplies a small plastic **** that's used to twist the top rebound adjustment. For Stock type autocross you have to remove the rear shocks to get access. I could do both sides in approx 10 minutes total, (3 bolts each) but never changed them after the first year. If your class allows it you can drill a hole through the hatch area, use plastic brake bleeding type tube as a guide and slip a home made tool down for quicker adjustment.
Jeff
Jeff
