Who make stiffer springs for the C6 Vette
Old 10-28-2010, 02:52 PM
trapp
trapp's Avatar
Default Who make stiffer springs for the C6 Vette
What vendor or company makes upgraded (stiffer) springs for the C6 Vette (Z51). I want to stiffen the suspension alittle without dropping the height of the car.. Any recommendations..
Old 10-28-2010, 03:11 PM
davidfarmer
Support Corvetteforum!
davidfarmer's Avatar
VBP probably, T1 springs from GM.....
Old 10-28-2010, 05:08 PM
MySR71
MySR71's Avatar
Hyperco makes composite leaf springs too. LG has them.
http://www.lgmotorsports.com/catalog...oducts_id=1569
Old 10-28-2010, 07:28 PM
0Anthony @ LGMotorsports
Former Vendor
Anthony @ LGMotorsports's Avatar
St. Jude Donor '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13
Just going to say that.
I have two different versions of that spring. They have a 'Street' and a 'Track Spring'.
We supplied Bondurant School with the Street Springs for all of their C5 school cars. Depending on what you want to do we can go a number of different ways with them.
Old 10-28-2010, 09:44 PM
Gman57
Gman57's Avatar
Just bought the track Hyperco springs from LG..... and will be installing them soon.
Old 10-29-2010, 01:26 PM
0Vector Vette
Former Vendor
Vector Vette's Avatar
Hyperco is the way to go. We can install here as well.
Robert
Old 10-29-2010, 02:31 PM
gkmccready
gkmccready's Avatar
Just for the record:
C6 Base: 420# / 620#
C6 Z51: 526# / 645#
C6 Z06: 531# / 782#
Hyperco HPS: 565# / 765#
C6 T1: 582# / 850#
Hyperco HPT: 625# / 850#
VBP Extreme: 1000# / 700# (I think?)
These rates are not comparable with coilover spring rates unless you calculate wheel rates, but I will note that the lightest coilovers I know of are 425# / 575# which is approximately the same front rate as the HPTs, but somewhat higher rates in the rear. The heaviest coilovers I've heard of are in the 800# range front and rear...
I have this theory that coilovers, which are a falling wheel rate from droop->bump, need to start with a higher initial rate because the leaf springs seem to be rising rate from droop->bump because the spring pad effectively slides further out the A-arm as it goes through the arc. But I could be completely wrong. :-)
Old 10-30-2010, 11:50 AM
jasonberkeley
jasonberkeley's Avatar
If anybody happens to have a C6 T1, Z06, or Z51 rear spring they want to get rid of, I need one! PM me please!
Old 10-30-2010, 03:56 PM
Gman57
Gman57's Avatar
PM to ya
Old 10-30-2010, 04:50 PM
jasonberkeley
Thanks! Reply sent!
To Who make stiffer springs for the C6 Vette
Quick Reply: Who make stiffer springs for the C6 Vette
