Firestone Fire Hawk's - Camber experience?
Old 10-28-2010, 09:57 PM
andrewdonald1
andrewdonald1's Avatar
Default Firestone Fire Hawk's - Camber experience?
Going to be doing a lot of work to the suspension on the C5Z coming up.
I'll then be swinging in for a corner weight/alignment.
I am running Firestone Fire Hawk Wide Ovals as the car is a DD.
Anyone have any experience with how much neg camber they can handle but still give some good wear/mile ratings?
Old 10-29-2010, 12:22 AM
LeMans05C6
LeMans05C6's Avatar
I am running the Firehawk Indy 500s (non-run flats) once i get my stroker built and up and running i am going to need to look into an alignment as well. All ears!
Old 10-29-2010, 07:24 AM
UstaB-GS549
UstaB-GS549's Avatar
It's not the camber as much as the toe settings that will cause accelerated wear. I bought FWO tires for the street and they have not shown a lot of wear with -2 in front and -1 in rear.
Keep your front toe near zero and you will get good mileage from your tires.
Old 10-29-2010, 09:42 AM
CHJ In Virginia
CHJ In Virginia's Avatar
I run the Firestones as my every day drive tires. Have -1.75 deg camber on front and -1.0 deg on the rear - Zero toe. The tires show virtually no wear after 5000 or so street miles. The actual tread width is about 1" less than the stock Goodyears the car came with ( even though sizing is the same ) so the camber is not that critical. The previous poster is correct in that out of alignment toe will eat the tires much faster than negative camber.
Old 10-30-2010, 12:54 AM
Greywolfe
Greywolfe's Avatar
I also am running wide ovals and daily driving. -1.8 front camber and -1.0 rear camber. Zero toe.
I don't get much wear from street driving but man I need more neg camber up front as the outside inch of the front tires are wore down alot and the rest of the tire is fine. Rears are not that big a problem.
I need more neg camber...
Old 10-31-2010, 09:31 PM
QwickerRon
QwickerRon's Avatar
2002 Z06 ....-2.3 front -1.6 rear....front total toe 0.00....Rear toe .12 I hear the W/O's are/have been discontinued. Wear just fair at those settings
Old 10-31-2010, 10:50 PM
andrewdonald1
I hope they are not discontinued! I like them as a DD tire.
To Firestone Fire Hawk's - Camber experience?
Quick Reply: Firestone Fire Hawk's - Camber experience?
