MGW Shifter instructions?
Old 10-29-2010, 05:30 PM
mountainbiker2
mountainbiker2's Avatar
Default MGW Shifter instructions?
Any one have instructions on how to install a MGW shifter? I also have a new C6 shift box that I have to install. The CD that comes with it doesn't work. So far this project is starting off good. C5 Z06.
thanks,
Steve A.
Old 10-29-2010, 05:58 PM
mountainbiker2
let's start with the C5 ****. How to remove.
Old 10-29-2010, 06:04 PM
wallyman424
wallyman424's Avatar
first question: are you reusing the ****?
if yes: do the following carefully
if no: just do it quickly
1. flip up the shifter pattern
2. there will be a piece of metal in there, affectionately called the demon key. Pry it out.
3. unscrew ****.
i'm sure if you search the forums for c5 shifter install, you'll come up with a bunch of hits.
Old 10-29-2010, 06:05 PM
wallyman424
http://www.c5forum.com/diy/hurstdiy.php
there, its the same pretty much for the MGW.
Old 10-29-2010, 07:02 PM
mountainbiker2
Thanks. It's all in. Pretty easy job. Know let's go see how it works. I didn't adjust any stops. I don't know if it even has it. Looks like MGW is going to get a call. They were closed when I started this project.
Steve A.
To MGW Shifter instructions?
Quick Reply: MGW Shifter instructions?
