Polish/blast the control arms for looks?
Polish/blast the control arms for looks? Results!
Before you get all over me I am not going waxer/show car. I just figured since I have a spare set off the car I would try making them look nice. Too much time on my hands.
They do end up pretty bad looking after a lot of miles.
The FRONT UCA seems to have been made to a smoother finish then the others & is easy to shine up.
All the others are more rough cast so pick up dirt/oil/road grime & it stays there.
I have tried green scrub pads, sandpaper, alum polish, and brass (wire) wheels (which seemed the best so far).
It's difficult to get a uniform finish.
Have not done any media blasting yet.
I have used various acids/chemical cleaners none of those really shined them up much.
Anyone ever try this with some good results?
2021 C1 of the Year Finalist - Modified
I used brown scotch pads soaked with mag wheel cleaner ( use rubber gloves). Looked pretty nice to me. If you are really bored you could follow up with alum polish.
Received 1,754 Likes
2023 C5 of the Year Finalist - Modified
St. Jude Donor '09-'10-'11
Actually by sanding out the casing lines and bumps, you are relieving any possible stress fracture points and strengthening the arm by polishing it.
I figured out a way to do it pretty easy & nice result.
I will post some pics tomorrow when the light is good for a pic.
Cost $10 and about 10-15 minutes an arm.
Those are rear UCA's that originally looked pretty much like the front LCA on the left.
