Which paint for track wheels?
VHT wheel paint - good to 250*; VHT engine enamel - 550*; caliper paint - 900*. Using flat black over 18" stock C5Z06 rears.
I painted some old wagon wheels with Duplicolor Engine Enamel ~500* after sanding and priming. Looked really good for a few months then faded and chipped. Another coat brings them back to looking good. Wheels were less than $100 but I wouldn't do it to anything nicer than that.
I use a gloss black engine paint. Just hit them with a quick touch up every so often. You know, using no masking tape or sand paper. Maybe wipe off the brake dust first.
Location: Deal's Gap 2004 NCM Motorsports track supporter
Received 1,103 Likes
I simply wiped down with dupont paint prep using scotch brite followed by high temp caliper flat black and the wheels still look good with only a minor scratch or two after 3 sets of track tires. I was skeptical at first not using primer but you don't need it. I feel better not powder coating at high temp for track use.
Thanks.
I found your thread about doing yours, so I am skipping the priming and got some scotchbrite. I missed the part about the DuPont paint prep. I think I will try the airplane stripper on the barrels to see how they do. I might do my SSR GT7 barrels in flat black also if it turns out alright. I just wasn't sure how much heat they wheels take on the track. Jury is still out on whether or not the powder coating heat is bad for them, so why take a chance. Besides not too hard to mess up track wheels.
Thanks.
Thanks.
Besides, don't you have a set of those really nice expensive wheels from forgeline? How long is a set of hoosiers lasting you anyhoo?
The other issue with powdercoating track wheels is that the coating makes it harder to see cracks, if they happen to develop.
I painted my old GTO track wheels with Duplicolor wheel paint and then a couple of coats of the wheel clearcoat. It held up ok but needed to be redone at the beginning of each season. One trip through the kitty litter off the end of Turn 8 at Watkins Glen tore them up pretty good though.
