Is there any fix for the stock seat "popping" issue
I end up with the gangster lean on about 50% of my autocross runs.
What I mean is the reclining mechanism on the right side of the seat gives way causing me to have to hold onto the wheel for dear life since the seat no longer supports me.
I drove another vette today at our last event of the year and his problem is even worse than mine.
It's time to finally fix this in the offseason if I can. If not, I think I'll just get some high density foam and cram it behind the seat so it doesn't have any room to move.
Does anyone know how to fix it?
Not that I know of. They changed to a cheaper mechanism in '02 I believe. Both of my '03 are a POS. Only thing that helps is I pull the lever every time I get in the car. It seems to help. My buddy had his let go at Spring Mountain and put him into the weeds.
I would like to put some sort of inflatable bladder behind the seat to keep it from letting go.
I replaced the recline mechanism which WAS available as a separate part & it helped some, but it still happens every so often.
Reset each run seems to help too.
I can't believe the seat even passes federal standards.
I had the exact same issue with my 06 when I first started tracking it.
VERY unsafe at high speeds. The entire rear, inner portion of the seat needed to be replaced.
I would not autocross and certainly not track it until you get it fixed.
OR,
Get you a race seat
OR,
Get you a race seat
Having that happen at high speed was not something I was ready to take a chance on.
If you start out that way, I can see where that would be tolerable
In any event, it can be fixed
The stock C5Z06 seats suck. When I bought this car last Fall, the seats immediately showed themselves at CMP as a weak point. Nothing like accelerating out of T11 or T1 or T4 only to have the right side of the seat back pop back a notch or two. Kinda like cruising on the boulevard, “Yo man, whassup???” The after shifting to 4th on the straight, I would have to readjust the seat back in time to hit the brakes for the next turn. There were several laps where I adjusted the seat back on the front straight, the short chute to T4 AND the straight between T7 and T8.
I know you said you couldn't do it, but my cure was to go to race seats.
-Kevin
-Kevin
Unfortunately, the real real solution is $$$ (going to ASP)...
Kenton
This is the only safety issue I've found with the cars. My Z06 has only done it once since I've owned it, but my coupe does it all the time. You must reset the lever before every run to reduce it's occurence.
I too don't know why a GM fix hasn't been found and why it hasn't been recalled. Nothing worse than coming off the line at a ProSolo with your foot to the floor and suddenly find yourself looking at the ceiling and clinging to the steering wheel for life.
Received 8,928 Likes
Bill
If you find a solution, or create one, I'd support the letter to the SEB to allow it.
Bill
This is a real frustration point with me and the SCCA SEB on the idea of "Stock" classes. You are allowed to change a sway bar, adjustable shocks and run wide tires but not wheels, but in the interest of safety you cannot change the driver seat unless going to ASP! I know in some situations it could be a 10-15# difference, but then again I could go without a few meals and get some of that weight from the very same place on the car.
I'm lucky I've not had mine pop out yet, still I would prefer to swap out the seat.
I also reset the seat before every run. It has become a habit. It doesn't always work though. I guess I need to go on a diet.
At this point I'm thinking just some high density foam crammed behind the seat. Anything more "technical" than that might not be legal (and would be beyond my means to create it)
Well I bought a 2"x24"x108" sheet of ultra density foam padding I'm going to try to use somehow. Wont have time for a few days to start working on it though.
