C5 Shifting Problem
Old 11-08-2010, 10:32 AM
varkwso
varkwso's Avatar
Default C5 Shifting Problem
The T1/ST2 car is causing me pain. When it is cold the gears work fine, on the warm up lap and maybe even a couple of laps the gears work fine. Then it comes out of gear fine but will not easily go into gear (no grinding sounds). The trans cooler seems to defer this problem as does the bleeding of the clutch (love those remote bleeders!) - but it always comes back well before the race/qual/practice ends. It is worse if the car is "loaded" in braking or pulling G. It has a new C6 shift mechanism and base. It is not a gate problem.
It has a T1 legal clutch (ZO6 I think?) with less then 20 days on it (I think), the clutch master looks new, I think the trans was fresh last Sep (need to check with previous owner) and makes no noise at any time.
I need to fix it before Road Atlanta in Dec or else I will be eaten alive in ST2 running only in 4th....
Help appreciated...
Old 11-08-2010, 03:41 PM
Jaymz
Jaymz's Avatar
Jeff... I would check out the clutch. I had them go with only a couple of weekends on them. The fingers seperate and cause issues. One other thing that seems to be a big bandaid on clutch issues is to get a bigger clutch master cylynder. I had an AP unit in my car for a while and it helped it out. Danny should be able to point you where to get one.
Old 11-08-2010, 04:05 PM
gmccreary
gmccreary's Avatar
Can you fix mine too? I had the same problem at Roebling Road this weekend.
Old 11-08-2010, 06:43 PM
varkwso
varkwso's Avatar
Bummer. I want to keep the car T1 legal if possible so not sure if bigger master will work. You will not have that constraint more then likely.
It looks like I need to find a lift and some hands to swap a clutch or at least to pull exhaust and inspection plate.
Old 11-08-2010, 06:44 PM
varkwso
varkwso's Avatar
I am leaning toward the clutch - talked to Danny today.
Old 11-08-2010, 07:53 PM
drivinhard
Support Corvetteforum!
drivinhard's Avatar
You need a Q Masta
Old 11-08-2010, 08:18 PM
gmccreary
gmccreary's Avatar
Originally Posted by drivinhard
You need a Q Masta
Are you offering to install it?
Old 11-08-2010, 09:47 PM
vette6aut0x
vette6aut0x's Avatar
Just throwing this out there, what fluid are you running? The wrong fluid can cause what you are describing.
David L.
Old 11-09-2010, 12:44 PM
varkwso
varkwso's Avatar
Originally Posted by vette6aut0x
just throwing this out there, what fluid are you running? The wrong fluid can cause what you are describing.
David l.
srf in clutch.
Whatever Jerry Onks put in the tranny.
Old 11-09-2010, 01:23 PM
Jason
Jason's Avatar
CI 4-5-6-7 Veteran
Mine was similar in that I could shift a couple times around the paddock and up to 4th, but opposite in that mine would then hang in 4th and not let go.
It was broken bits inside the trans.
Old 11-11-2010, 02:52 PM
The Spark
The Spark's Avatar
I was having that problem on a stock C5 clutch when it was loaded as you described. I could not downshift into 2nd. It was like it was blocked - no grinding. Would go into other gears ok.
I did not have a bleeder on the clutch but did try the method of replacing fluid and pumping the clutch. I replaced the shifter with C6 Z06 and made sure it was aligned per directions. No help. It wasn't every turn at the track but was consistent with certain turns.
I was also having sticky clutch pedal problems.
I replaced the clutch with LS7, master and slave. That solved my downshifting problem.
Old 11-13-2010, 07:53 AM
varkwso
varkwso's Avatar
Trouble shooting at Roebling yesterday confirmed the clutch is the issue. Now I need to pick a lightweight clutch/flywheel and get in by Road Atlanta.
Old 11-13-2010, 03:01 PM
gmccreary
gmccreary's Avatar
My shifting problem was caused by a broken tab inside the clutch. Thanks to sperkins for the fix.
Old 11-13-2010, 04:44 PM
sperkins
sperkins's Avatar
Now there are only 11 more to break off.
Old 11-13-2010, 04:55 PM
varkwso
varkwso's Avatar
Shouldn't take long.
Old 11-13-2010, 05:42 PM
drivinhard
drivinhard's Avatar
BTDT (twice)
mine tried to escape
To C5 Shifting Problem
Quick Reply: C5 Shifting Problem
