The shifter exploded in my hand
For those of you frustrated by the constant repairs and maintenance required to enjoy this sport 'at the limit', here's another story for the record books:
On October 29th I had my car delivered to Autobahn CC. It was in the shop for repairs due to an engine bay fire during my October 1st GT RACE - see video and story on previous post:
http://forums.corvetteforum.com/auto...tober-1st.html
Black Dog Speed Shop came out for support for nearly the full day, and the car was running great. Nearing the end of the day, my buddies from Black Dog called it a day, and headed home. I had 2-sessions left, and decided this might be it for the season, so I pushed ahead. Next session was much like the earlier sessions . . . no problems, just a grin from ear to ear, and having to watch the clock until the next and final session.
A couple laps in, and I'm tearing it up (literally in hindsight) down the back straight. As I shift from 3rd to 4th, I'm guessing around 100mph, the shifter EXPLODES in my hand, and the drivers cockpit fills with white smoke. TWO FEET IN, and I turn the motor off, coasting to a stop half on the track, half off (I avoid the grass to lessen the chance of another fire). My assumptions were either a MOTOR, TRANS or DIFF. None of those were good, but some better than others.
TRY DRIVE-SHAFT and TORQUE TUBE:
The Drive-Shaft is SEVERED - never seen anything like this before!
The Torque-Tube was blasted: The donut seems to be the cause of smoke in the cockpit:
I'm certainly open to a discussion, and thoughts on how to prevent this in the future!
Location: If you don't weigh in you don't wrestle Road America
We see the damage to the torque tube was that the only piece that failed?
The input shaft still seems to be attached to the driveshaft so the doughnut was still holding things together right?
What kind of shape is the rest of the driveshaft in?
What it looks like to me is that the torque tube broke at the weld, we've seen torque tubes crack in the past but I haven't seen one come apart so suddenly and completly like this one. Usually it's an issue with the doughnuts or the driveshaft, but in this case those pieces seem to be intact. Glad you weren't hurt!
Former Vendor
Rubbers start to go and it starts the process of destruction.
The tube it self has a few welds on them, over time they do "work harden" and fail. The tubes themselves seem to do well until something like this happens.
Randy
1 Post
W. Detroit Events Coordinator
Cruise-In VI Veteran
Cruise-In VII Veteran
Cruise-In VII Autocross Champ
You can buy solid aluminum piece to replace the rubber ones, mine had one medal and one rubber, it will get two aluminum ones.
I guess I can see the reasoning behind replacing the couplers from time to time as well as the driveshaft. But I wouldn't think that the torque tube would get brittle and fail. I can see if there was more force on the torque tube, but I never thought that the torque from the engine would cause it to spilt in half.
So would solid couples be better or worse for this? The solid couplers would keep the driveshaft from "whipping", but again is that better or worse for the driveshaft?
It's not like you have these things out all the time so it's tough to know when it's time to replace.
Motor upgrade = driveshaft upgrade = Run Forest Run.
On the plus side, your car will be stocked with fresh components on the big ticket items.
Should be a fun 2011 for you Don!
Mike
Mike
Former Vendor
Everything fails, work over time
Randy
I have to pull mine this week due to a bad vibration. I've been considering solid in the rear and poly/alum hybrid in the front.
I figured that it needed at least one side with a little flex to absorb any harmonic vibrations. There's a lot of rotating stuff inside there. Is my thinking right?
Are you really surprised that your driveshaft coupler failed? By the looks of it in the picture, it had been failing for some time. The disintegration of the coupler is what sawed the torque tube in half.
Is that a stock aluminum driveshaft in the photo?
There have been many posts on this forum about the problems of the stock rubber couplers and the stock aluminum drivehsaft. What made you think you could run those components in a serious road race Corvette?
If you want to avoid those types of failures in the future save your money and purchase a Pfadt Racing carbon-fiber driveshaft with its solid couplers. End of problem!
Oh yes, change the title of your post. Your shifter did not explode!
Was your experience something like this?:
http://www.youtube.com/watch?v=YRcydiI7k1E
Everything in my car is solidly mounted. I'm on my 4th torque tube and I expect it to go anytime now.
I no longer use solid couplers since I think harmonics will happen and something has to absorb it.
Sorry to hear about your DS.
How many miles did you have on yours?
@Randy@DRM,
How often should a carbon fiber driveshaft with a single aluminum coupler be replaced? It's mostly just the guibo(sp?) joints that crap out right?
I only went with a solid engine mount on the passenger side, so theres still some damping action to reduce the vibrations.
@Randy@DRM,
Change the title of your post? Really? Do you have a sense of humor?
FYI:
1.) No, I'm not surprised the coupler failed. This is only the 2nd time in 4-years, but it did fail in such a way that my race shop (Black Dog Speed Shop) hadn't seen in the past.
2.) What made me think I could run those components in a serious road race car? My car has been an evolution from street to race for several years. I didn't plunk down $ 50,000 to convert it overnight, and MOST of the components have been upgraded. Unfortunately I upgrade on an 'as needed' basis.
3.) Buy a Pfadt drive shaft, solid couplers, problem solved? My drive shaft had been converted in April 2010 to a solid (billet) coupler on one end. The part was in very good condition at that time. I have several Pfadt parts on my car, and Aaron has been helpful, most recently with his Competition Sway Bars. Those were added as I was getting excessive roll-over, and tire wear using T-1 bars. My shop has suggested solid couplers on both sides, and my Thread Post was intended to either confirm that or solicit other options.
Pumba, read all of the replies above and below yours. The tone is alot different than yours. Regardless of your knowledge and/or experience, you sound like an a-hole.
Best of luck!
1 Post
