Camera with data overlay options
What are the options today for video systems with data overlaid on video (tach, speedo, brake / throttle position, etc)?
The more flexibility in the input signals the better, and GPS integration for track position is useful. I'm thinking under $3k. Any links to your videos with said systems would be helpful.
Thanks!
Thanks!
RLC with a Chasecam looked the best.
Race Logic has a good setup - DL1/Dash1 w/their video setup.
Also Traqmate and a Chasecam (a bit more limited for analysis, but might be adequate for you).
I have a Chasecam with the data module, OBDII cable and everything is automatic.
Great system for sure
Nice
I am using Traqmate for logging, GoProHD for movie and TrackVision for movie generation. I like the HD format of the camera and how I can make nice overlays to the movie.
But one kit is of course easier than three systems to connect.
From last Friday http://www.youtube.com/watch?v=yTy4O42SYYM
PeO.
PeO.
I am a simple soul so I stuck a brake LED, a speedo and a rear-vision mirror in front of the camera.
(actually two speedos - the little HUD on the windshield is readable in the 1024p video)
(could hang some fluffy dice from the rear vision mirror to log lateral G's too!)
I put a brake light Led in front of my camera too! Best $2 I spent on racing parts!
Now I have a DL1 which has GPS and accelerometers which makes it more accurate in faster transition sections. You can also wire in a lot of additional sensors.
The Video 4 add on looks pretty nice.
PeO.
PeO.
Does the Traqmate accept OBD II data? I'm thinking several of the OBD II parameters would be very informative. For example, throttle position, brake position, steering position, yaw sensors, etc. If the TraqMate can't do this, then I wonder if I could integrate the GoPro and TrackVision with something like an RLC Micro-Pod (which does accept OBD II inputs).
We use the smartycam, it connects to the MXL Pista and can be configured to show any of the connected sensors (oil pressure, water temp, diff temp, etc.). Here is some footage from Sebring a few weeks ago with HSR.
The smartycam itself is $999, it can be used alone or with your with the AIM MXL. Of course by itself it wouldn't show tach, pressures, temps, or gear position. I thimk the MXL system starts at about $1999 for the base setup and then depends on what you want to add to it.
Bob - No, I dont think Traqmate has ODBII connectivity. I have a rpm signal that I have not yet connected in this car but I use in my M3. http://www.youtube.com/watch?v=jT78Gdkpqxk
PeO.
PeO.
Flinky ... what brake LED ? I don't see anything lighting up when you brake?
The new'ish DRIFT HD170 is nice in that it incorporates a mini monitor and rotating lens/camera assembly, so that you can easily frame up your shot and level it. You can also plus or minus the exposure so that you can properly balance your exposure inside and out.
BUT ... I had to test THREE of them before I got one that was sharp! We think B&H Photo Video just got a bad batch of cameras. The one I got locally, from a distributer, not a store ... was fine. It was a mad scramble to get a good one in time for the BRIDGESTONE commercial that we're about to shoot. We're shooting mainly on film, but use mini cameras for certain shots.
http://www.driftinnovation.com/
The little remote is also nice
... but basically I'm a GoPro evangelist. They really are the sharpest. And with the new firmware update, they have LiveView. The new clip on monitor will be available in January.
