hearing airplane sound on right side of car when driving
Old 11-13-2010, 08:08 PM
mark b
mark b's Avatar
Default hearing airplane sound on right side of car when driving
I was just on NJMP lightning today and on my way home I'm hearing like an airplane sound coming from the right side of the car...
since lightning has only two left turns, I was doing alot of right turns..
could my wheel bearings be on their way out? or could it be the balljoints? I have never heard this sound I didnt hear it when i was on track.. the sound is more pronounced when turning right..
anyone experience this? what should I replace? thanks
Old 11-13-2010, 09:39 PM
SouthernSon
Support Corvetteforum!
SouthernSon's Avatar
Location: Deal's Gap 2004 NCM Motorsports track supporter
Received 1,103 Likes on 717 Posts
I've had aftermarket wheels (motorsport) rub against my wilwood calipers when in turns that sound similar to cards in the spokes of bicycles. But since you didn't hear it at the track, I have no idea. I suppose you may find the source after more investigation if you look at the whole suspension/chassis setup.
Old 11-13-2010, 11:02 PM
bobmoore2
bobmoore2's Avatar
Hard to know what "like an airplane sound" sounds like, but I would guess that you have a failed wheel bearing on the right side of the car.
Jack the car up on the right side to get both tires off the ground. Grab the tire at the top and the bottom. Pull on the top while pushing on the bottom, then do vice versa, a few times. If you can feel a slight movement, then that bearing is definitely bad. If not, there still is a small possibility of a bad bearing, but probably not. Repeat for the other right side tire.
Old 11-14-2010, 01:20 AM
Dirty Howie
Dirty Howie's Avatar
Piper Cub or 747 ?????
Old 11-14-2010, 02:35 AM
longdaddy
longdaddy's Avatar
another vote for bearing, mine was making the "airplane" sound (accurate description, actually) long before I could feel any play.
better test is to take the wheel off and just rotate the hub by hand - if it does not rotate smoothly, it's going.
Old 11-14-2010, 04:28 AM
WNeal
WNeal's Avatar
Cruise-In Veteran VII
Cruise-In Veteran VIII
"Slower Azz Dog"
St. Jude Donor '06-'07-'08-'09
Mine and a buddies both sounded like a low pitched hum, before being able to actually feel it, and when turning.
My vote is for the bearing
also,
I just had a complete left rear hub failure at Putnam about 3 weeks ago. Bearing was fine but hub completely separated.
I thought the tranny or something let loose but replaced the bearing and everything was fine.
If it had been the front, the wheel would have come off.
Old 11-14-2010, 10:31 AM
mark b
mark b's Avatar
I knew it was the wheel hub bearings... thats the only thing that makes sense.. I will check the car tomorrow and see if there is play in the wheel.. Im going to replace the whole right side, front and rear.. the left is quiet..
its funny because the car still is performing normally..
and it sounds like a hearing a small airplane pass by up in the sky... the pitch gets higher the faster you go and past 100 it is bairly audible because the whine is high pitched.. that is why I did not hear it on the track...
Old 11-15-2010, 08:17 AM
SouthernSon
You might consider the newer, stronger SKF bearing. That seems to be the bearing of choice for the track. Be aware there are two different flavors of SKF from what I understand. Get the stronger one.
Old 11-15-2010, 09:37 AM
Webz
Webz's Avatar
Interesting short video of HD SKF hub. It's amazing what having more ***** will do!
http://www.youtube.com/watch?v=3Qyrg...layer_embedded
Old 11-15-2010, 10:27 AM
SouthernSon
Yep. It is better no matter how you 'spin' it.
Old 11-15-2010, 03:58 PM
mark b
mark b's Avatar
yeah I looked at the SKF's... they are three times the price.. the stock ones last me for about a year and ahalf.. I use Nitto r2's if i was using hoosier's I probably would consider it.. I get them for 160 apiece at rockauto...
To hearing airplane sound on right side of car when driving
Quick Reply: hearing airplane sound on right side of car when driving
