Have you spent the extra cash for poly bushings?
Old 11-14-2010, 12:51 AM
Gman57
Gman57's Avatar
Default Have you spent the extra cash for poly bushings?
As I'm seting up my track/TT car to this point I've not skimped on anything. With the suspension I'm installing Pfadt shocks, comp sways and Hyperco T-1 springs. In addition I will be running A6/R6's
The Question is this..... with the car only having 3K miles on it would you pull the trigger and buy a Control Arm Kit with Poly/Aluminum Sleeves and Camber kit? Use the OE bushings with the camber kit or skip the camber kit till it's time to replace the bushings and do it all then? It's almost 900 bucks I could put some other place or would this be a good investment now.
Thanks for your input
Old 11-14-2010, 01:21 AM
sperkins
sperkins's Avatar
Installing Pfadt's poly bushings in my car was the best performance mod I've ever done by far. That along with Gary's shock bushings dropped my lap times at Rd. Atl and at CMP by 2 full seconds.
Old 11-14-2010, 06:31 AM
gmccreary
gmccreary's Avatar
Why are you up at 1:21 AM?
Old 11-14-2010, 07:39 AM
CHJ In Virginia
CHJ In Virginia's Avatar
If the car is track only and you are after the last competitive edge - go for it ! If the car is a combination street / track car like mine is, I would wait. The stock bushings will serve you well for quite some time. The poly bushings will be a PITA to live with on the street requiring frequent disassembly and lubrication to stay quiet.
Old 11-14-2010, 07:51 AM
AutobahnRacer
AutobahnRacer's Avatar
Bare minimum get the camber kit installed. Without it, you're going to get tire 'roll over', and excessive wear on the outside edges will trash your tires prematurely.
Good luck,
Old 11-14-2010, 08:35 AM
Poor-sha
Track Rat
Support Corvetteforum!
Poor-sha's Avatar
Received 3,400 Likes on 1,372 Posts
I'vev been running the Pfadt poly bushings on my street/track C6Z for over a year now and have no squeaking.
I recently put in Gary's delrin shock bushings after my rears completely collapsed from track use.
I also highly recommend the camber kit as I can easily switch from trac to street alignment in between events by just removing some washers and resetting the toe.
Old 11-14-2010, 12:05 PM
kmagvette
kmagvette's Avatar
Poly bushings were one of the best mods I have done to date...one of the cheapest too.
Old 11-14-2010, 07:13 PM
dvandentop
dvandentop's Avatar
poly is great bang for the buck mod
Old 11-14-2010, 07:36 PM
QwickerRon
QwickerRon's Avatar
Pfadt poly's. Best upgrade I've done
Old 11-14-2010, 09:04 PM
Gman57
Gman57's Avatar
Poly's it is...... I know if I don't, I'll regret it later
Might as well do it when I'm setting the rest of the suspension up.
Thanks for the input guys
Old 11-15-2010, 10:28 AM
throwit
throwit's Avatar
No need for a camber kit...
Forget the polys and get the spherical bearings...odds are, if you will be tracking the car competitively, you will get them later anyway...do it once, do it right!
Old 11-15-2010, 11:35 AM
yakisoba
yakisoba's Avatar
Oddly, you can get away with less camber if you go to harder bushings, because they deflect less. I run PFadt polys on my car and they were a good mod. Turn in was immediately better, and tire temps (across the tire) got more stable. I don't find them particularly noisy, though it is a track car, so it makes all sorts of weird sounds that a street car doesn't.
Old 11-15-2010, 01:24 PM
Gman57
Gman57's Avatar
Quiet like a school bus......
Old 11-15-2010, 10:10 PM
4wheels
4wheels's Avatar
If you go with poly, make sure they fit correctly when installed. Also make sure they are lubed correctly. And, I would add some provision for grease fittings, and make sure the grease can get into the center pivot point of the bushing correctly. Poly usually develops lots of stiction to metal over time (i.e. as the grease gets pushed away).
Old 11-16-2010, 02:16 PM
RX-Ben
RX-Ben's Avatar
Polys are cheap if you don't value your time.
My Pfadt polys are quiet, 7 track days in, about 2k street miles. I cut the big ones in half when I installed them, fwiw. I plan to lube them 3x/year or more if needed.
To Have you spent the extra cash for poly bushings?
Quick Reply: Have you spent the extra cash for poly bushings?
