28' Enclosed Haulmark Edge trailer FS (NC)...
Old 11-17-2010, 06:30 PM
94ZR1#444
94ZR1#444's Avatar
Default 28' Enclosed Haulmark Edge trailer FS (NC)...
This 2004 trailer was $14,600 new. It’s the middle model as I didn’t need the observation platform that the Ultimate Edge had, nor did I want a plywood interior that the base model had. It has approx 10K+ miles on it. All 4 hubs have been completely repacked and all 4 of the brake pickups replaced. It has 4 brand new Load Range E tires. This trailer is READY to haul. It needs nothing. I will deliver to VIR if payment in full is made prior to delivery.
This trailer is in GREAT condition. It has been taken well taken care of. I don’t need to sell it, but I don’t really need it any more, at least for right now. I’ll probably regret selling it. My loss, your gain.
$8500 OBO, don’t bother to low ball me or ask for more pictures unless you are serious.
I have the title in hand. Remember, I said "OBO".
PM me or email thru my signature info.
28’ Haulmark “Edge” Trailer – Victory Red
Model: EG85X28WT3
Width: 8 ½’ – 100” Wide Body
Width Between Wheel Wells: 82”
Safety Chains: 12,600lb Gold Safety Chains w/Gold Hook
4 Brand New Maxxis Load Range “E” tires - Less than 200 miles on tires
Aluminum Fender Flares
Axle Width: Wide Track
Hub Type: EZ-Lube Hubs
Suspension: Tandem 5200lb Axles with Torflex (Rubber Ride Suspension)
GVWR: 10000lbs
Brakes: Electric Brakes on both axles
Wheel Accessories: Chrome Wheel Caps, Chrome Lug Nets with 4 Wheel Locks, 2 Key Socket Locks
Wheels: 6 Bolt Pattern with ½” studs
Wheels: Aluminum with 12 Holes
Cap: Stainless Cap – Not the Base model plastic cap that will crack and leak
Finish: .030 Aluminum Exterior
Floor Covering: ¾” Plywood Flooring with complete ATP Floor covering
Insulation: Insulated Ceiling
Main Rails: 2” x 8” Tube Main
Rust Inhibiting Chassis Protection
Crossmember Spacing: 16” on center
Crossmembers: Z crossmember
Chrome Rear Header
Nose & Corners” Stainless Steel Front Nose Cap, Cast Aluminum Corners
Roof: 1 Piece Aluminum Roof
Roof Bow Spacing: 16” on center
Roof Bows: Hat Section Roof Bows
Sidewall Construction: Dust Resistant Sidewalls
Sidewall Liner: 3/8” Plywood Sidewall Liner with .030” Aluminum wall liner
Stoneguard: 24” ATP Stoneguard
Vertical Post Spacing: 16” on center
Vertical Posts” 86 ¾” Hat Posts
Interior Height: 79” – Your head won’t be hitting the fluorescent lights
Side Door: 48” Door with Recessed-lock
A-Frame Coupler: 2 5/16” 10,000lb coupler with Break-away switch
Beavertail: 96” Beavertail with spring and Cam-Locks
Lighting: 12V Deluxe Dome Light
Fluorescent Lighting: 110V 4’ fixtures with Diffuser
30A Circuit Breaker Panel
Shore Power: 30 Amp exterior plug near generator door
Air Conditioning: Carrier AirV 13,500 Nominal BTU Cooling Capacity w/Heater strip
L-shaped Aluminum Work Bench/Overhead Cabinets with Generator Door
Generator Door: 36’ x 33”
Added by myself since purchasing new:
Storage shelf: 4’ x 8’ x ½” Plywood rack on E-Track that can be easily removed if needed.
Tire Rack – Holds Five or Six 315 width tires – Folds up if needed
Exterior Dual 110V Outlet near Side Door and one near Beavertail
2 Sets of 5Klb D-Ring Tie-down rings – 8 total D-rings
Wall Mounted E-track to tie-down rolling Tool Chest under Tire Rack
Fuel Storage: 1 rectangle box that holds two 5 gallon square fuel jugs
Brand new spare tire/wheel: Goodyear Marathon ST225/75R15 BSL 2540# 65PSI on factory 12 hole Aluminum wheel
4’ extended ramps with rubber/nut retainer
Available if you want to purchase:
TV/DVD to play a couple of GGW DVD's I'll throw in, not for the faint of heart - $50
Shore Power cables – Two 50’ Marinco Marine 30A cables on Storage reel - $80
Drive Up Ramp to change tire - $10
Horse Step - $25
T-ring tie-down attachments - $15
Craftsman 5 drawer tool-chest - $100
Four 3-ton Car-stands - $30
Craftsman 4 ton floor jack - $100
Microwave - $50
Last edited by 94ZR1#444; 11-18-2010 at 09:53 AM. Reason: Added Year of Manufacture
Old 11-17-2010, 08:56 PM
murcman1
7th Gear
murcman1's Avatar
I am still in the market for a trailer, what year is it? I'm located near Road Atlanta. I have a corvette zo6 and looks like it would do the job. What is your lowest price? I will make it a swift transaction if we can get together, my e-mail address is murcman1@aol.com, phone no. 404-626-3481 thank you, Mike
Old 11-18-2010, 12:53 AM
dvandentop
dvandentop's Avatar
damn that is a nice clean trailer, hope it sells quick for you!
Old 11-18-2010, 06:04 AM
gmccreary
gmccreary's Avatar
That is one nice trailer
Old 11-18-2010, 06:57 AM
varkwso
varkwso's Avatar
I will vouch for the trailer and the seller. Both are top notch.
We have missed seeing you by the way.
Old 11-18-2010, 08:10 AM
myles930
myles930's Avatar
The temptation is overwhelming.
Old 11-21-2010, 06:00 PM
94ZR1#444
94ZR1#444's Avatar
Weekend TTT...
Old 11-21-2010, 06:13 PM
Falcon
Falcon's Avatar
Damn! This thing hasn't sold, yet? WOW! I thought this was sold!
For those of you guys who think you may ever need a trailer, this is the buy of the decade. If I didn't already own one, I'd jump on this in a heartbeat.
This is a sweet trailer.
Old 11-21-2010, 07:50 PM
redtopz
redtopz's Avatar
I would sell mine and buy this trailer if it wasn't on the other side of the country . I have a 20' bare bones enclosed trailer now, but that one is awesome. And it's red .
Old 11-21-2010, 08:31 PM
eogel
eogel's Avatar
I know Mark and have bought from him and he is great to deal with. What I bought was exactly as he presented it.
Old 11-22-2010, 07:13 PM
varkwso
varkwso's Avatar
TimZO6 needs to buy it now!
Old 11-22-2010, 07:22 PM
Falcon
Falcon's Avatar
Yep, that'd be the perfect trailer for him.
Old 11-22-2010, 07:39 PM
Fast-Eddie
Fast-Eddie's Avatar
A friend of mine here in Atlanta just got a C6Z STO racecar and said he is going up tomorrow to pick the trailer up. He will be at the NASA Toy Run, only doing HPDE until he gets his SCCA LIc. next Feb.
Look's like a great buy.
Old 11-23-2010, 02:39 PM
94ZR1#444
94ZR1#444's Avatar
It's SOLD....
Mike just picked up the trailer and is headed for Atlanta.
THANKS Jeff, Jody and Ed. Much appreciated.
Old 11-23-2010, 04:48 PM
Loco Vette
Support Corvetteforum!
Loco Vette's Avatar
Location: Loaded like a freight train, flyin' like an aeroplane!
CI 2-3-4-5-6-7-8-9-10-11 Vet
CI X-XI Blind Cart Auto-X Champ
CI VI Autocross Champ
CI VIII Autocross Champ
CI VIII Cone-killin' champ
St. Jude '03-'04-'05-'06-'07-'08-'09-'10
Originally Posted by 94ZR1#444
It's SOLD....
Glad to hear it went to a good home!
To 28' Enclosed Haulmark Edge trailer FS (NC)...
Quick Reply: 28' Enclosed Haulmark Edge trailer FS (NC)...
