What 5 Pt harness do I need for HARDBAR ?
Guys:
I'm not a hard core racer like some of you, but I might do some AutoXing at some point for fun. I really like being held into my seats tight... I love my turns...
I have Corbeau A4 seats, with Corbeau seat brackets.
Am planing to get a HARDBAR.
I think I need a "wrap round" harness for the HARDBAR right ?
I was thinking of getting the Corbeau Harness but It looks like from the pics on there web site it is not a wrap around type.
Can anyone point me in the right direction on what harness to get ? I like the 3" cam lock style. Will the Corbeau work for my setup ?
What else should I be looking at to get to install this type of harness ?
Thanks in advance for your help !
Toque
Toque
The absolute best harness is a teamtech jet pilot. It's a "six point" and the nice thing is the lap and thigh belts are combined a the attachment point. You only need the normal two mounts on either side of the seat for the entire lower belt assembly. I simply installed some eyelets on my hardbar rails and had teamtech build the lower part of the harness with snap in connections so I could quickly remove the harness when not in use.
Teamtech are super high quality and built to order so there are a ton of options. Look over their site and figure out what you need. You may want to measure your thighs. You can order through hardbar when you figure out what you need. The teamtech catalog will walk you through getting the corrrect part number.
Received 8,924 Likes
Bill
A 6 point is much better for the "wedding vegetables"
For autox, I just use the lap and should belts. So I would get a 6 pt and then just use the 4 straps for autox and then use the full 6 for track events.
I did notice that you are in Texas and I have seen some fast 3rd gear events there so maybe you do want to use all 6 pts for autox.
Good info thanks guys !
I don't have the 5th hole in the Corbeau seat. If I get serious enough I will have to get the 5th hole in the seat. For now I will just use the lap, and shoulder straps for playing around autoxing.
I don't see "wrap around" as an option on many of the belts I found online.
Thanks !
Toque
Thanks !
Toque
Got my Jet Pilot from Gary at Hardbar I recommend it.
Thanks !
Toque
Thanks !
Toque
Bill
Thanks !
Toque
Thanks !
Toque
Also, some sanctioning bodies will not accept harness belts that do not go through a hole in a seat. Some SCCA events will be like this as well as PCA (Porsche Club) events.
G-Force also has a complete installation kit for their belts. Comes with everything needed to install the harness belts. The lap belts use the same mounting location that the OEM seat belts use and you get slightly longer bolts in the kit. That way you can continue to use the OEM belts for the street (most all harness belts are not DOT approved) and simply grab the harness stuff and buckle in for competition.
Personally I would not use just the shoulder belts as there would be nothing to keep you from sliding forward at the hips if you come to a "sudden stop". The sub strap will keep you from moving forward.
All belts can be configured with either wrap around, snap in, or bolt. One thing I forgot to add above for those not familiar with the jet pilot, is because of the way the bottom belts are done they do not need additional holes in the seat.
St. Jude Donor '11-'12-'13-'14-'15
The BK Lap/Sub mount brackets eliminate the need for a hole/s in the bottom of the seat also...
That Jet Pilot is pretty neat! I'll have to check into that...
Tim
Tim
St. Jude Donor '08
I would think it would be able to come around the front of the seat?
Chris,
In the sake of safety, the sub-belt for a 5/6 point harness cannot be configured to come up over the front of the seat. In the event of a front collision, the sub-belt's purpose is to keep the lap belts in position across your hips. The sub-belt does this by effectively pulling down on the lap belts when your body moves forward during the impact. If the sub-belt is mounted to come up over the front of the seat, during an impact it will act as if you are "pushing a piece of rope" and the resulting "play" can allow the lap belts to move up as the shoulder harnesses pull on them. That is why sub-belts are mounted to go through the seat near your crotch and then get mounted slightly rearward of that opening under your body.
Make sense?
-Kevin
Chris,
Make sense?
-Kevin
Make sense?
-Kevin
Having the sub belt go across the front of the seat is probably worse than not having one at all. With it running across the front of the seat it will actually be pulling the lap belt away from your pelvis.
Bill
St. Jude Donor '08
Chris,
Make sense?
-Kevin
Make sense?
-Kevin
Good luck,
TomK
In my opinion (I am not an automotive engineer), it would not. I would stick with the OEM 3pt if I could not implement a 5/6pt harness. In the event of an incident, an OEM 3pt will allow the right half of your torso to come forward a bit before the belts lock and cinch. This helps prevents submarining under the lap belt, which is what the sub-belt does in a 5/6pt harness.
At some of the track events I work, we do not allow 4pt harnesses at all. It is either OEM 3pt or 5/6pt for the reason I described above. We always have a lot of dicey discussions when any of the Factory Five Cobras show up that have 4pt Simpsons installed from the factory.
However, use your best judgement and check with any groups you run with prior to arriving to see what they will allow.
-Kevin
