Disconnect airbags
Old 12-02-2010, 10:01 AM
WKNRACR
WKNRACR's Avatar
Default Disconnect airbags
What is the best or correct way to permanently disconnect the airbags
in a c6z06. Also (the yaw sensor ?) mounted in center console, okay to remove it once airbags are disconnected? This is a track car only.
Thanks.
Old 12-05-2010, 03:59 PM
John Shiels
John Shiels's Avatar
Location: Buy USA products! Check the label! Employ Americans
C5 you can pull a fuse for the air bags not sure on your car.
Quick Reply: Disconnect airbags
