Dec & Jan Corvette C5 And C6 Track Setup & Suspension Work
Old 12-03-2010, 05:54 AM
jfaphoenix32
Supporting Vendor
jfaphoenix32's Avatar
Default Dec & Jan Corvette C5 And C6 Track Setup & Suspension Work
Kurt is back from testing at Homestead and is ready for more setups on his alignment equipment...
Situated in his all new shop in phoenixville Pa. (19460), his set up includes...
1. Inspection of ball joints, tie rod ends, suspension bushings, control arms, shocks and other components that may affect the handling of your Corvette.
2. Set ride height to whatever spec you choose, or one we recommend for your use.
3. Set corner weights to achieve maximum cornering
4. Set Camber, caster and toe to agreed upon specs or ones we recommend for your usage.
5. Mount and balance tires, reverse your used tires if thats what you need...
6. Pennsylvanis state emissions test and safety inspection.
Through the whole process, you can ask questions., look over your car and follow along.. Depending on the amount of work to be done, it could take anywhere form 3 to 6 hours, so you will have time to tour the other shops, see what is under construction in the race car shop, body shop and down in the engine building and cage shops...
Give a call for an appointment... 610-482-0141. We have openings startiing Tuesday September 28th...
Joe
Old 12-05-2010, 09:30 AM
jfaphoenix32
Supporting Vendor
to the top
Old 12-05-2010, 09:36 AM
sebdavid
sebdavid's Avatar
I might be passing through the area with a new purchase. How much do you guys charge per hour? I'd be interested in checking alignment and corner weighting the car (T1 suspension).
Old 12-05-2010, 09:40 AM
jfaphoenix32
Supporting Vendor
PM sent.
Old 12-05-2010, 11:10 AM
John Shiels
John Shiels's Avatar
Location: Buy USA products! Check the label! Employ Americans
my friend may be coming over now for a set up as long as he can wait for the day. If I have time for my car I may be over this winter too. He has a C6Z
Old 12-13-2010, 08:01 AM
jfaphoenix32
Supporting Vendor
Thanks john...
Kurt can do it while you wait..
Old 12-17-2010, 12:14 AM
jfaphoenix32
Supporting Vendor
At the shop this saturday to take calls or visits!!!
Old 12-19-2010, 10:44 AM
jfaphoenix32
Supporting Vendor
Thanks all for stopping by... Always fun to talk about Corvettes!!!
To Dec & Jan Corvette C5 And C6 Track Setup & Suspension Work
Quick Reply: Dec & Jan Corvette C5 And C6 Track Setup & Suspension Work
