Let's talk rain tire sizes..and tires
First off, I'm no engineer or physicist--
I've heard in the past that slightly smaller sized tires are best for the rain. Why is this? Wouldn't you want a greater contact patch just like in the dry? Or does the contact patch actually work against you to cause hydro plane if the tire doesn't spread enough water? (the whole weight and load transfer I suppose would come into play with that..)
So being that I have upgraded to 18" wheels on my T1 car I need a set of rains just in case (there was a rain event this past year..). What are everyones experience with Hoosier Rains vs. Good Year RS rains? Also have you tried the Toyo R888's against either of the other 2?
I ask about the R888's because I have a set of 295/305s in the garage..
Received 1,741 Likes
2023 C5 of the Year Finalist - Modified
St. Jude Donor '09-'10-'11
I cannot comment on the brand of tire, but narrower is definitely better. Think of it this way, the same weight is concentrated on a narrower, smaller patch of tire. This allows the tire to cut through the water where as a wider tire will want to ride on top of the water.
Smaller tread width is definately better for wet conditions. Not sure about other brands, but Hoosier's wets are typically wider than their DOT tire in the same size. A 275/18 wet will be considerably wider than a 275/18 A6 for example.
FYI - there is a guy selling a set of 275/18 Hoosier wets on the NASA forum right now.
Optimal wet tire sizes depend on standing water or just wet. Going through puddles , narrow will be better.......track just wet, wider will be better. I always had the "wider" because those were better suited to the wheels I had .....
I have some 315-35-17 Hoosier radial wets and wheels (CCW's) that I may (probably) part with, I have to be on 18's now......California is a long ship though :>(. PM if interested.
I have some 17's for sale too, I'm on 18's now for the AP brakes :o
You were right on the 275/18's. I have a good friend that is selling some 245's though.
http://www.nasaforums.com/viewtopic....9b5d44f#unread
Reviving this - I'm looking for street tires that can double as rains. I had some variation of Nitto 555s that were terrible in heavy rain. Downright dangerous.
I'm thinking of the Conti ExtremeContact DW as a replacement, stock sizes. These will need to do TT duty, if it is wet, as I don't have space to haul enough wheels/tires.
Anyone have any other suggestions? The Hankook S1 evo is apparently an impressive wet tire (based on Euro tests), but it is no longer available and its replacement (V12) is not as good in the rain.
Thanks.
Thanks.
Thanks.
Thanks.
I should add, the GS-D3s seemed better at higher pressures. I think I used 40F 38R.
Received 8,924 Likes
Thanks.
Thanks.
Bill
