Want to buy - Wheels
I need a set of 18x10 front and 18x11 rears for use on a T1 racecar. I am using C6Z06 brakes front and rear and need to have wheels that fit over the brakes.
Thats what I would run on my T1 car when not doing SCCA events.
I have a set of CCW C10's in that size. Shotpeened and anodized. Excellent condition. Actually, I only need to sell the rears as I am installing wider rear fenders so I need wider wheels/tires in the back. The other option is to sell the fronts, move my current rears forward, and purchase the 13" rears new so I can use the set for track only. I'm willing to sell the set, but I don't want to lose my *** on them because I would have to buy a new set of the same wheels again. Below is a picture of my track set of the same wheels I used to have, but 11"/12" widths. They look the same, but the lip on the rears in the photo is only on the 12" or wider wheels.
They're specifically allowed on C6s. C5s may also run a Wilwood SL6R 6-piston caliper. C5 line also says "C6 calipers allowed" but I think that refers to the stock slide-rails.
http://cms.scca.com/documents/Club%20Forms/GCR-Dec.pdf
C5 T1 car and the Z06 caliper is not allowed. See GCR 647. Also the SL6R is better than oem but not by much it is said but cheaper than any of the real race systems like the AP's or the Stoptechs or even a BremboGT which is more of a light track/street set-up.
Yes but OP said running 18x10 and 18x11 which means he is running a
Good luck with finding your wheels, OP!
Apologies to the OP for the side-track, but "max wheel size" doesn't mean prescribed wheel size. So far as I know the C6 cars are running 18x10+18x11s. And you've obviously never used the SL6Rs if you're saying they're not much better than the stock slide-rails... they're significantly better for pad wear and heat tolerance and they don't spread like the slide-rails. I agree GCR 647 leaves it open to interpretation what "C6 brake calipers allowed" really means now that all C6s are permitted Grand Sport (aka Z06) brakes.
I thought c6 was running 19" rear. Ap during development of their t1 brake blew up sl6 on dyno.
I never ran sl6. I was development car for stoptechs 4 caliper 4 piston t1 brakes.
I have the wilwood sl6 calipers and have been running them for a couple years now with no problems. I like the 20 mm pads they run. I just finished converting my C5Z to T1 and bought some used 17x10 and 17x11 ccw classics from another forum member. However, they don't fit over my sl6 calipers. Did I buy the wrong wheels or do people just use spacers to make them fit?
Location: Deal's Gap 2004 NCM Motorsports track supporter
Received 1,103 Likes
Yeah, my stock 17" wheels fit over my SL6's so I figured the 17" ccw's would fit also (wrong). Looks like I'll need a pretty large spacer to make these work. Thanks for the info.
The SL6R is the full width (7420 pads). The SL6 is the narrow (7416 pads). There's also a Wide-5 version of the caliper with a narrowed outboard body that uses the 7420 pads. Gary must have really changed his tune on the SL6Rs because he's the one that sold me mine!
The CCW LM20 (Lip Monster) supposedly clears big brakes; anybody check with John & Chip? Their Corsair wheels should all clear easily. My 18x10+18x11 on my C6 have tonnes of room.
