H/C LS2 + HPDE.... oil system concerns?
Hey guys,
Saw in a thread recently where many expressed serious concerns about the stock LS2 oiling system when pushed hard around a track. I'm planning to attend a handful if not more HPDE's next year and am looking for some thoughts around this topic.
During the engines upgrades I've added a ported stock oil pump and C6Z oil cooler to the mix with all else being stock at this point. Is there anything I should be considering here? Someone mentioned something about the oil pan but it wasn't clear exactly what.
My stock LS2 ('06) hits low-teens for oil pressure pulling 1.2G around T2 at Thunderhill -- sustained left hander -- DRM coilovers, Toyo R888 tires. I've been thinking about a trap-door oil pan (http://www.flyinmiata.com/index.php?...umber=26-04110) but really think if I want to run Hoosiers I need a dry sump... FWIW, the Flyin' Miata guys confirmed with their supplier that the pan I linked *should* fit a C6...
Stay off the Rev limiter, add an extra quart of oil and you should be OK You have the oil cooler so should be good to keep those temps down
Best is an accu-sump or dry sump and oil cooler.
Have at it and have fun
I agree.
I agree.
again I think the biggest suggestion we have seen with H/C cars is to stay off that rev limiter. Shift before the red line.
High RPMs & high lift cams ( Over .590 lift ) Kill valve trains faster then most ppl think. ( LS1tech Guys are a bit shy on experience on road courses ) Check your springs half way through your summer and next winter.
Watch your oil temps ( 260 and under is great) and engine temps. May think about a bigger radiator
Change your oil after two events and send to black stone for oil analysis. This will tell you what is happening inside your engine.
Oil recommendations: 15w-50 or 40wt racing oil
Keep us posted on your fun.
Premium Supporting Vendor
Location: Providing the most proven supercharger kits for your C5/6/7 609-752-0321
Received 1,085 Likes
agreed
Its somewhat tough answering this question, since a lot of it is up to the driver and his/her capabilties. The faster you are, the more you are in need of a dry sump or at least accusump. Mods also come into play, tires etc.
I just finished nine months of work getting this onto the road:
I'm running one of V8R's oil pans, here's a different view of it. It's designed for the LS1; if the LS2/3 pans are the same configuration as the LS1 you should be good to go:
Y'all have a Merry Christmas and Happy New Year!
Mike
Thank you everyone for the great information! Seems like I am in good shape based on the responses which is good to hear.
I'm just looking to get some seat time in and better my driving at the limit while having some fun.
I'm still looking for a set of C5Z wheels and will likely run a "good" tire that won't break the bank but still give me the much needed grip I'm looking for. I'm very familiar with the hp I have under the hood so no surprises there. Any tire suggestions for these wheels? Would love to run 18's all around but if not what about the 17/18" setup for tires?
as i had been running the same thing last year but not quite 7 qts but i may want to if i switch tires. I did RP and the engine itself seemed fine but maybe a thicker version may be in order, especially over the summer here in Texas.
I am building a 403 stroker for HPDEs and will be looking at getting R888s to hold that power better. 234/238 cam with .601/.603 lift with 114+2LSA was a relatively low lift cam but should still work alright. I did TEA stage 2 Heads with that came and the stroker in my LS2 with a new FAST102 and NW102 along with the CF112 Halltech SuperBee Intake with beehive and shroud cutouts.
***reason for all that was the bolts on my stock camshaft sheered off back in oct***
I will be getting up towards or over 500rwhp so i worry about temps and oil pressure as well. I am having an oil pump shimmed to increase the pressure which should help when the oil gets thing like that at high temps.
FYI, i would have done suspension first but the engine went first.
When it comes to keep the car cool, what about Ron Davis Radiators versus others. Heard once they were one of the best just curious to keep temps down.
Former Vendor
It really depends:o
Randy
