Torque Specs-Trouble Codes-DIY Info here
Old 12-21-2010, 09:14 AM
davidfarmer
Support Corvetteforum!
davidfarmer's Avatar
Default Torque Specs-Trouble Codes-DIY Info here
haven't posted in a while. Take a look. My torque spec PDF's continue to be extremely popular. I keep them in my "dropbox" so that I can access them via my iPhone!
http://www.davidfarmerstuff.com/
Also lots of other good stuff, various fitting info (coolers, accusump, Weatherhead etc), alignment info, Quartermaster Clutch info etc!
Enjoy!
Old 12-21-2010, 09:44 AM
wmckeenster
wmckeenster's Avatar
Thanks David, what a wealth of information and you have been gracious enough to share.
Thank you from all of us!
Old 12-21-2010, 09:48 AM
VetteDrmr
VetteDrmr's Avatar
Received 1,395 Likes on 748 Posts
David,
I've just about worn out my laminated pages from the torque specs pdf files you made available to us a few years ago. Thanks for periodically getting this out to the new folks here.
Have a good one,
Mike
Old 12-21-2010, 10:04 AM
John Shiels
John Shiels's Avatar
Location: Buy USA products! Check the label! Employ Americans
Old 12-21-2010, 10:31 AM
spdislife
spdislife's Avatar
David....your website is in my favorites and have used it numerous times for torque specs etc. Thanx for taking the time to share it
Old 12-21-2010, 01:41 PM
sperkins
sperkins's Avatar
I too have that page bookmarked on my iPhone and use it nearly everyday while under the lift.
Old 12-21-2010, 06:30 PM
RX-Ben
RX-Ben's Avatar
Super helpful info! Required! Print out the tq specs and laminate or cover in clear packing tape. 2 copies, since you'll always be looking for the other one.
Thanks David!
Old 12-22-2010, 11:36 AM
TmillerC5
TmillerC5's Avatar
St. Jude Donor '08
Just printed a couple of things myself.
To Torque Specs-Trouble Codes-DIY Info here
Quick Reply: Torque Specs-Trouble Codes-DIY Info here
