T1 a-arms question
12-31-2010, 07:31 PM
T1 a-arms question
I purchased a set of new front upper T1 a-arms in a private sale. Are there any identifying marks on the T1 arms - to distinguish them from the stock replacement Z06 a-arms ? In other words, how can I verify that these are in fact T1 a-arms ? Also, are the T1 arms identical to the standard issue Z06 replacement arms, other than the stiffer bushings ?
12-31-2010, 08:11 PM
St. Jude Donor '06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17-'18-'19-'20
Do they have a part number stamped somewhere? Even the $2 plastic door plugs I just bought have a part number on the part.
12-31-2010, 09:40 PM
they are the same arm, they just have a stiffer bushing. I doubt they have different labeling on them. Poly is much better regardless.
01-01-2011, 05:54 AM
Location: Buy USA products! Check the label! Employ Americans
Quote:
Originally Posted by
davidfarmer
on both counts they are not going to make a separate casing to have a different number.
01-01-2011, 08:13 AM
John Shiels
ok...but you would think there would have to be some means (marking / labeling / tag / etc) that would ID them as T1 pieces.
01-01-2011, 09:09 AM
I've bought brand new arms from a forum sponsor and they had labels with the P/N and GMPP logo attached to them.
01-01-2011, 12:52 PM
C5_Z06
that makes sense as it is just a label which is cheap
01-01-2011, 12:56 PM
John Shiels
FWIW, GM swaybars show up the same way... labelled, not stamped.
01-01-2011, 12:58 PM
It was the same on the sway bars, a paper label attached with a thin metal wire through a hole in the part.
