Anyone have install pics of a accusump on a C6
Old 01-01-2011, 05:57 PM
vertC6
Support Corvetteforum!
vertC6's Avatar
Default Anyone have install pics of a accusump on a C6
Just trying to get some ideas of placement of the accusump. I want to install the 3 quart and some had said to install it on the passenger side front front fender (where the z06 dry sump tank would be). I read that a 3 quart doesn't fit on the drivers side like it does on the c5. Any thoughts or other placement ideas?
Old 01-02-2011, 11:36 AM
vertC6
vertC6's Avatar
Anyone???
Old 01-02-2011, 12:03 PM
mfquinn
mfquinn's Avatar
I am also interested in installing this in my LS3. Since I don't have the dry sump, I am looking for extra protection.
Old 01-02-2011, 01:18 PM
Webz
Webz's Avatar
Default Accusump 08 LS3
FWIW.
Old 01-02-2011, 02:42 PM
LEAVINU
LEAVINU's Avatar
Not sure I'll need one of these so asking out of curiosity........ how is the 3qts of additional oil added to this unit?
With the stock Z oil is added directly into the dry sump tank so how does this work when added to a non-dry sump car?
Old 01-02-2011, 03:00 PM
mfquinn
mfquinn's Avatar
Webz,
Is that your car? If so, can you provide any more pictures and install information please?
Thanks.
Old 01-02-2011, 03:12 PM
Webz
Webz's Avatar
Originally Posted by mfquinn
Webz,
Thanks.
It is my car. Unfortunately I did not take any pictures during installation.
Old 01-02-2011, 03:17 PM
gkmccready
gkmccready's Avatar
Webz, who made the bracket for the Odyssey?
Old 01-02-2011, 05:14 PM
vertC6
vertC6's Avatar
It fills from the oil pressure from the motor, it has an internal piston that equalizes the air pressure behind it with the oil pressure from the motor.
Old 01-02-2011, 05:16 PM
vertC6
vertC6's Avatar
Originally Posted by Webz
FWIW.
That looks as if it is installed in the inner portion of the fender instead of the c5's that most have installed outside of the engine compartment.
Old 01-02-2011, 06:11 PM
Webz
Webz's Avatar
Self made by yours truly.......
Old 01-02-2011, 06:14 PM
Webz
Webz's Avatar
Yeap
To Anyone have install pics of a accusump on a C6
Quick Reply: Anyone have install pics of a accusump on a C6
