engine question
St. Jude Donor '06
engine question
I now have my fresh engine installed in the car,the intake and coil mounts are much to high,will require a huge bulge in the hood..who knows if FAST or anyone makes an intake that will allow me to use the hood with out cutting it to pieces and having to look around the big scoop?? the engine has C5R heads,and the hogan intake that was on the engine is inadequate,,according to the engine builder...
I would post a picture but am a computer midget,on here
Johnny
Johnny
St. Jude Donor '06
The coil packs will not be a problem. plenty of options out there. Katech had a set-up that placed them off the covers to the side over the headers. Most will cover your pretty valve covers.
Mast Motorsports coil sidemounts..
http://www.mastmotorsports.com/2010/...e Covers&id=49
Its the intake that will give you a problem. Plenty of guys have adapted LS7 intakes in C5's, but I'm pretty sure that the C5R head does NOT have the same intake bolt pattern/inlet. I may be wrong.
Have you contacted wilson to see if they can make one of their billet LSX manifolds to fit C5R heads?
http://www.wilsonmanifolds.com/produ...manifolds.html
Here are a couple more options...although expensive
For photo information only:
http://www.kinsler.com/NewProducts/P..._CarbonWeb.jpg
Harrop version...
http://www.harrop.com.au/root_folder...rricane-1.html
http://www.harrop.com.au/root_folder...rricane-2.html
Harrop version...
Platinum Supporting Vendor
Johnny,
Just break out the sawzall, that would be a loss of about 2 pounds.
Car looks good, my fingers are crossed that your bad luck is behind you. Hopefully I will be out with you guys this year. Here is the latest of mine.
[IMG][/IMG]
[IMG][/IMG]
Love the look of that car!
Like stated above the coil relocation is no problem.
I would definitely start making calls on the intake. Should not be too hard to adapt a Fast intake, have something made or give Kinsler a call.
Dropped your rockers off to Zack Friday morning.
Is that the Performance AFX cage????
St. Jude Donor '06
thanks for all the help and suggestions,guys..I'm making a mount for the coils from aluminum,and will make a bulge in the hood for the throttle body...then something more exotic later,if the engine stays together this time.@.Payton, the tuner has refused to tune my car for me ,so I'll ask then to send me the rockers,,when I spoke with them today,Jeff said he had not seen them..
the car is all together except the dry sump lines..brown and miller are coming on wednesday, to do the plumbing and then I'll have to find a tuner than can tune it correctly,,what a nightmare this has been...
wallyman,,I wouldn't want you to have this motor...we're friends......
I personally handed
The rockers to Zack. They are in a box with my name and address on them.
Not sure what kind of room you have to the firewall, but you can mount intakes from LS motors backwards and they bolt directly up. You may not have to alter the hood too much and you can take fresh air from the cowl's high pressure area.
katech option #2. save you some time...
http://cgi.ebay.com/ebaymotors/Katec...Q5fAccessories
St. Jude Donor '06
Johnny
