My New Toy
My New Toy
Been tracking for over 7 years in a modified C5 and for the last year and a half in my C6 Z06. Got tired of the expense as well as wear and tear on the C6 Z06 for track duty. The C6Z makes a great "track" day car but I'm driving it as a "race car" which is taking it's toll. It's also just a matter of time to when I have an off track excursion which would be expensive to fix on the C6Z.
I'm also tired of switching camber and toe, street to race rubber, brake pads, etc. every time I go to the track, not to mention switching it back to street after an event and the clean-up required to remove track debris/marking.
Car was an ASA car which has been converted to a road course car. Engine specs are provided below the photos. There's also a link showing a good pic of the dry sump LS1 engine. I haven't had a chance to take of the silly *** NASCAR style vinyl stickers/graphics yet, it's been cold!
Should be fun. Now I just need it to warm up enough to get to drive it!!!
Rick
http://www.racecars360.com/Corvette_Tech/ASA_LS1.html
ASA LS1-V8 Engine Specifications
General
Displacement............................ ...5.7 Liter (5665 cc)
Horsepower.............................. .....430 @ 6200 rpm
Torque.................................. ...430 lb-ft @ 4800 pm
Compression Ratio ........................................ 10.1:1
Bore/Stroke............99.0 mm x 92.0 mm (3.9” x 3.62”)
Firing Order..................................1-8-7-2-6-5-4-3
Bore-to-Stroke Ratio................................... ...1.08:1
HP per Liter................................... ......................75
Fuel Shut Off..................................... ........6500 rpm
Redline................................. ...................6500 rpm
PCM..................................... ............................32u
Balancing............................... .....................Internal
Mounting................................ .....Front Longitudinal
Cylinder Block
Material.........................Aluminu m 319 T5 Heat Treat
Description..900 V, Deep Skirt with Cast-in Iron Sleeves
Bore Spacing................................1 11.76 mm (4.40”)
Deck Height................................ 234.70 mm (9.24”)
Main Bearings
Material.........................Aluminu m/Lead/Silicon Alloy
Number of Bearings................................ ............Five
Thrust Bearing................................. .Center Bulkhead
Bearing Caps
Material................................ ...............Powder Metal
Attachment............Four Vertical Bolts, Two Cross Bolts
Cylinder Heads
Material.................Cast Aluminum 356 T-6 Heat Treat
Description....Cross Flow, Wedge Combustion Chamber
Ports....................Hi-flow, Evenly Spaced, Symmetrical
Chamber Volume.................................. .........67.3 cc
Head Gasket.............................Compr essed 1.33 mm
Crankshaft
Material................................ .........Cast Nodular Iron
Features.............................Und ercut and Rolled Filets
Journal Diameter
Crank Pin.....................53.338 mm / 53.318 mm
Main Bearing.................65.008 mm / 64.993 mm
Pistons
Material................................ .....Cast Aluminum
Description............................. .Strutless Flat Top
Compression Height..................34.0 mm (1.34”)
Weight.................................. ......44 g (15.5 oz.)
Intake Manifold
Material ....One Piece Composite with Injector Seats
Features.............................Sym metrical Runners
Throttle Body
Manual.................................. ............Aluminum
Bore Diameter............................75.0 mm (2.95”)
Electrical System
Alternator Amperage...............................5 0/120
Starter................................. ...................PG260
Electronic Ignition............Hi-Energy Coil near Plug
Description............................E ight Separate Coils
Spark Plug................AC 41-931 Dual Pad Platinum
Gap..................................... ........1.5 mm (.060”)
Fuel System
Type...................................L imited Recirculation
Fuel Rail.................................... .............H-Style
Material........................Fabricat ed Stainless Steel
Regulator............................... .............Bosch D2
Pressure................................ .400 kpa (constant)
Injectors............................... ............. Bosch EV6
Recommended Fuel............... Premium 91 Octane
Cooling System
Type.................................... ..Conventional Flow
Coolant................................. ............Dex-Cool
Radiator Type.................................... .Crossflow
Relief Pressure............................103 kpa (15 psi)
Thermostat Open...........................860 C (1870 F)
Fully Open..................................10 00 C (2120 F)
Dual Fans..............................Two-Speed Electric
Pump Type.......................Centrifugal, Belt Driven
Rick
General
Cylinder Block
Main Bearings
Bearing Caps
Cylinder Heads
Crankshaft
Journal Diameter
Pistons
Intake Manifold
Throttle Body
Electrical System
Fuel System
Cooling System
Consumables were a MAJOR consideration in purchasing. A set of tires is only $600. Brake pads and rotors will last more than 2 days and are much less expensive.
They're now hanging the new Camaro bodies on these cars. They look great with the Camaro body.
Rick
My buddy bought an identical car last winter and I spent the last year helping him out. The cars are brutally fast, with an emphasis on brutal. I have driven the car a number of times, and it seems to scare the crap out of me every time....for the first lap or two. Then, it gets real fun real fast.
He has been finding tires brand new for $50-60. Look on Hoosiers site for their discontuined tires we well as our favorite auction site.
The biggest issue my buddy had was the rear diff was worn out. That leads to a very unstable car. It will change direction every time you accelerate or let off the gas.
It will probably take you a year to figure the thing out, but in my opinion it will be worth it. Get some ear plugs.
Ken
Ken
Received 1,762 Likes
ttt
I am saying you are going to have fun it that toy...
You're gonna enjoy! Outstanding, fast & safe racers. Mine has seen
180 mph in the tri-oval at Daytona. What a buy you got!
Hope you can make it to Road Atlanta in Nov.
Best of luck
Bosco
Best of luck
Bosco
We do need more GT-1 cars though.
I think he did it to keep David and his 997 off his back.
If he wants to make a trek to the South, otherwise SCCA GTA & NASA SU.
The V8 StockCar series races in the SouthEast at SCCA, HSR, and other events. Also sometimes under our own sanction, ie: with ARCA at Palm Beach in 2010, and with Grand Am & Trans Am at VIR this May.
four classes
V8SPO: Nascar cup car, busch, ARCA, & super late models
V8GTA: cars like Ricks ex ASA ride
V8 GT1: SCCA GT-1 & Rolex GT cars
V8 GT2: SCCA STO, GT2, T1, ITO, Nasa ST2, ST2 on steriods, ex Koni challenge cars.
Takes a strong effort to win in our classes:
Champs:
V8 GT1: Dave Machavern, ex Grand Am Rolex GTS champ, built and prepped by Road Racing great Tommy Riggins
V8 GT2: Bob Mayer SE Div SCCA Nat Champ (prepped by CrossRoads Motosports Sam Power)
V8 SPO: Larry Hoopaugh 3 time former Nascar Goody's Dash Champ
V8 GTA: Kurt Roehrig, Nascar Trucks, Busch, IMSA Camel GT, Trans Am
Season finishes at the ARRC at Road Atlanta
four classes
Champs:
At 2,600 pounds and real race rubber instead of DOT R compound I'm thinking I'll drop at least 5 seconds off my lap times at Hallett. I currently run low 1:25's like clockwork driving at 7 tenths.
Rick
Rick
Kurt Roehrig's V8 SC championship GTA car was for sale for 30K.
Very trick car built and set up by Roehrig, a racing engineer.
This car is as fast as many scca GT-1 cars. Has Schwanke LS1. He is in Lexington NC (Roehrig Engineering)
Another VERY fast one is Nascar Nationwide Driver Scott Lagasse Jr's
ex ASA car. He converted it to road race and set SCCA Daytona track record. Also very trick. STill has lingenfelter LS1. He is asking 25,500. Scott lives in the Mooresville, NC and St Augustine, Fl
AD for Lagasse's car
Nascar Nationwide Series Driver Scott Lagasse Jr's road race GTA car: One of the fastest GTA cars available; 1:58's @ Daytona.
raced once at Daytona since being completely gone through.
HOWE ASA CHASSIS WITH HIGH ANTI-DIVE FRONT CLIP (designed for max travel with additional bracing)
SIX PISTON AP CALIPERS WITH FLOATING PERFORMANCE FRICTION ROTORS
STRONG LOW HOUR DYNO'D LS1
SCHWANKE 6800 RPM ECU
CUSTOM WIRING HARNESS AND SWITCH PANEL
BODY AND WINDOWS BRACED FOR HIGH SPEED TRACKS, IE DAYTONA
PURPOSE BUILT PENSKE SHOCKS SET UP FOR ROAD RACE
LIGHTENED T101 A TRANNY WITH ROAD RACE GEARING AND POLISHED GEARS
LATEST SEAT AND SAFETY UPDATES
COMPLETE ROAD RACE TRIM WITH SPLINED FRONT SWAY BAR, REAR SWAY
BRAKE DUCTS & BLOWERS
LIGHT WEIGHT CAR CUT FASTEST LAP EVER AT DAYTONA BY GTA CAR
ALL REQUIREMENTS FOR V8STOCKCAR SERIES AND SCCA, HAS LOGBOOK
THIS CAR WON GTA AND OVERALL AT DAYTONA IN ITS' LAST OUTING WHILE RUNNING AT HIGHER WEIGHT FOR UPGRADED LS1 WITH ONLY THE RAISED RPM LIMIT AND WITHOUT THE LARGER INTAKE AND THROTTLE BODY. LOTS OF SPEED LEFT IN THIS PACKAGE.
THIS IS A NO EXCUSES, GTA CAR CAPABLE OF RUNNING UP FRONT AND WINNING! EXCELLENT CAR FOR THE NEW SCCA TRANS AM TA2 CLASS
OUR PROFESSIONAL RACING TEAM CAN WORK WITH NEW OWNER TO GET UP TO SPEED
NEW PRICE: 25,500
FOR MORE INFORMATION CONTACT: slagassesr at gmail dot com
FYI: Lagasse Sr is the ex Corvette Challenge, Trans Am, IMSA, Grand Am, ARCA, Nascar racer of note.
There are more available between the range I quoted.
Connie has all but disallowed me from running in HST with the C6Z. She winces when she sees me in the registration line. She says I "scare" people and for the life of me I have no idea why...
My plans right now are to use as a track day car more so than racing. On COMMA weekends as it's a GTA car so I guess I'll run the the GT group.
If you recall I usually go out on weekdays when it's just me and a couple other cars all running together. Street cars and race cars together. On a COMMA weekend I'm lucky to get 90 track miles/day. When I go out on a weekday I get 240 track miles/day.
Rick
