Buying a C5, Importance of Z51?
I am going to be buying a C5 in the next month or 2. It will be a daily driver, but I'd like to get a spare set of rims and tires and auto cross it occasionally. So how important is it I find a car with Z51 suspension? How would a base suspension compare if I upgraded the shocks and sway bars?Is it worth spending the extra time to get a car with Z51?
Received 8,918 Likes
Shocks and sways are only part of the Z51 package. The springs are stiffer than the base car springs and in my opinion they shouldn't have built the cars with anything less than the Z51 setup.
Bill
Bill
Stock or Z51 suppension Not the magnetic control.
In most cases for a used C5 the shocks may need to replaced.
You may wind up putting in money to the suspension anyway.
the PS cooler is a must.
Agree with the C5Z suggestion. If you are going to beat on the car you will end up spending a bunch of money to get what comes standard on the C5Z...including the power steering cooler.
The coupe is classed better
A C5 coupe with a Z51 runs in A stock. A C5Z runs in super stock.
The coupe is an overdog in AS, the Z is an also ran in SS against the Elise and the GT3's. You really don't need the power steering cooler for autocross, but you really want the Z51 package. You don't get quite the rim width, but you can still run 275 fronts and 315 rears on the stock wheels. There is a huge difference between the base and the Z51, so you should at the very least get that to start with.
Note that in SCCA stock the front sway bar is free, so you can upgrade to the Z06 front bar and aside from a bit of spring rate you will have 90% of a Z in terms of capability (assuming you go to the bigger tires up front). Add a set of serious shocks and dial the car in and you have a strong car out of the box.
There are some serious autocrossers that think that C5 Z51 coupe is a national level package for A stock, so there are good reasons not to go for a C5Z and stick with a coupe. If one was to get real serious about autocrossing a Vette on a national level a Z51 coupe might well be the best choice.
Thanks for the info everyone. Solofast, that's what I was thinking, I'd rather run AS then SS. I have used my Camaro in ESP before and had really good luck with it using Strano suspension. I will look for a Z51 car. varkwso, thanks for that info too. I am looking at cars and some are out of state, and they rarely list if they have the Z51 option or not. I'll have to make sure they send me a copy of the RPO codes before I go look at one.
I have autocrossed my FRC (Z51) and agree that it does quite well. I have since gotten stock Z06 wheels, which should make for more fun.
In any case, I think even if you can't find a coupe that is Z51 equipped, you can find used Z51 springs (seen these for as low as $150 a set) & sways (got the updated Z51 size sways for $75 for the pair) without too much trouble. As one poster said, you'll probably need to replace the shocks regardless, so grab a set of Bilstein Sport shocks (I got mine for $300 for all four, shipped), and a set of metal endlinks (if equipped with the plastic one) and you're good to go.
Sam is an excellent suspension tuner, imho he is probably one of the best at setting up cars for autocross. In addition to F bodies he knows his way around a C5...
You would do well to listen to him and do exactly what he says. Do that and drive the car well and you are all set.
Yes, when Sam talks, I listen, all my suspension settings on the Camaro are exactly what he told me to use. Didn't know he knew C5's as well. When I get one I will have to get ahold of him.
Thanks for the VIN-RPO code link.
Another C5 option is the 99-00 Fixed Roof Coupe. Change to the the Z06 exhaust and you are within a few pounds of the C5Z in weight. Also you want the Active Handling package. Properly set up you can run SCCA, NCCC and Detroit Council events with a minimum of changes to the Corvette.
In Michigan all three have active Corvette classes and you have the choice of several Corvette friendly autocross, Low and High Speed Time Trials, and limited passing HPDE events.
NCCC holds both low speed and high speed time trials. Low speed is your typical parking lot autocross while high speed is usually held on a road course like Gingerman. Check this site for schedule.
NCCC Michigan region schedule: http://www.michcorvette.org/id4.html
You can even come down to Indiana for some of our events, especially when we are at Tire Rack in South Bend.
NCCC Indiana region schedue: http://www.indianaregion.org/Schedule.pdf
Terminal Vette Addict
just upgrade the suspension with a GOOD aftermarket setup and blow away the competition. Also you run then in ASP which typically in most regions has very few competitors in it.
http://www.corvetteclubmi.com/. Usually two events or more every month from April til October.
If you are going to run in SCCA stock classes, or you just don't want to deal with a racing seat, you're going to want to check out Angel Pads at www.angelwingstech.com. The stock seats suck when it comes to lateral support. I don't know how I got by without mine.
