Installed Lexan. Picture.
I started a thread a couple of weeks ago about lexan rear window for a Z06. Here's the link.
http://forums.corvetteforum.com/auto...-a-c5-z06.html
My friend and I installed one yesterday. Saved 9lbs.
thanks for you help.
Steve A.
Steve A.
thanks I see the screws now on my second peek. i used SS finish washer which you countersunk in the plexi so it does not crack at the screws so easy. From Spruce Aircraft
How'd you install? Just lay down a bead of silicone and then screw into the SMC roof panel... the lip the OEM glass sits in/on? Did you pre-drill the holes? Did you consider using a nut/bolt so you can remove/replace w/o worry of your holes stripping out?
Steve
Get some Novus cleaner and polish for lexan. They sell it at Spruce Aircraft for planes. You may get it in a decent detail shop also or auto supply.
You can get a Lexan product called Marlite which nearly as resistant to scratching as glass. Not sure if can be bent.
http://www.modernplastics.com/lexanr...155fd42cc94338
wheelsup, I've installed lexan all the way around on a road race mustang. For the windshield I use dzus fasteners to allow easy removal for access to things like pedal assembly and master cylinder reservoirs. On side windows and such I use small threaded inserts typically and fasten with screws since those don't need to come out often or as fast yet they are still easily removable.
