Wheels for HPDE / TT
I am starting to put the final touches on 2004 Z06 for NASA HPDE's & TT in Midwest / Great Lakes region. I am wanting a 2nd set of wheels for track tires, so my question is what should I be looking for? I am wanting to run the same size wheel on all four corners in 18", will this be a major problem? Also, what wheel is available under 20lbs that will work without breaking the bank?
For more neutral handling, you want a wider tire on the rear. Narrow 275's front and rear and the car will be too easy to bring the rear around. Stock Z06 Speedlines are a great choice and regularly available here for a very reasonable $. I run 295/17 on the front and 315/18 rear on stock wheels with excellent results. Using stock rear 18's all the way around with 305 front and 315 rear is also a very good combination.
1 Post
W. Detroit Events Coordinator
Cruise-In VI Veteran
Cruise-In VII Veteran
Cruise-In VII Autocross Champ
I have run 43's at CMP on 9.5's with an almost stock car (T1 bars), stock weight, so they do ok.
1 Post
& I've run 33s at Mid Ohio on 9.5" so you aren't really giving up much
Received 1,751 Likes
2023 C5 of the Year Finalist - Modified
St. Jude Donor '09-'10-'11
Granted I have a C4 but I plan on running 275s all around this year on C6Z 18x9.5 front wheels.
