Size of jamb nuts on C6 rear toe links
Hi all,
I'm starting to tinker with the new C6, and I need to buy some new wrenches. Anyone know the size of these jamb nuts? Is the car a combo of standard & metric fasteners?
Appears to be close to a 21 mm...I know this because I have 20- and 22-mm wrenches!!
Also, do you guys grease the outer end on a regular basis, as per owners manual?
Thanks!
Thanks!
It doesn't matter what size it is, you just need to invest in metric tools for now and especially for the future. I have had almost all the bolts off my Z and so far I have not found any American Inch-spec bolts. All metric. However, GM likes to use some non-standard metric sizes such as a 16mm head rather than the normal 15 or 17mm. The only wierd bolts that I have come upon are the head bolts. What is up with that? They are bigger than a 10mm but smaller than a 12mm. They have a standard 1.75 pitch thread but could they actually be 11mm? Any body able to chime in?
Gary
Gary
I've got quite a few metric tools already, just not combination wrenches in the larger sizes, so I have to buy them piecemeal. The Vette is the first American car I've owned (9th car overall).
Former Vendor
1 Post
Hi all,
Thanks!
Thanks!
How do I know this? I align between 200 and 350 Corvettes each and every year and have for the last 5 years (before that it was like 50 to 100).
For a C5 and all C6s, the Tie rod is a 13mm and the Jamb nut is a 7/8". Don't ask me why, they just are. The accentrics are 21mm.
Gary
One more question: I'm looking to get about -2 degrees camber up front, and maybe -1.0 to -1.2 degrees in the back. Is this amount possible through factory adjustments, or do you have to take other measures? Thanks in advance!!
Former Vendor
1 Post
Awesome information....thank you very much!
Sidebar:
Unless you are really fast on Racing compound tires, IMHO it might be a bit much to run that much neg camber unless you are confirming the reasonability of those setting with pyrometer readings.
fractional decimal mm
7/8 " 0.8750 22.2250
