engineering help
Old 02-13-2011, 12:05 AM
VGLNTE1
VGLNTE1's Avatar
St. Jude Donor '14-'15
Default engineering help
So I have some extreme strong plastic sheets I'm going to use to build a splitter on the bottom of my ACI splitter...it will go all the way and smooth the bottom of the car...the problem is...I'm not sure how to secure a flat sheet on the bottom. Has to be sturdy for at least 180+MPH...I know alot of you have the ACI....any thoughts?
Old 02-14-2011, 07:02 PM
John Shiels
John Shiels's Avatar
Location: Buy USA products! Check the label! Employ Americans
splitter on a splitter? Why? Have a picture of the car with ACI now?
Old 02-15-2011, 11:02 AM
VGLNTE1
VGLNTE1's Avatar
the ACI really isnt a splitter...and im mostly building an undertray..
right now it just looks like every other c5 with a ACI
Old 02-15-2011, 06:03 PM
Speed Direct
Premium Supporting Vendor
Speed Direct's Avatar
Build some metal brackets and secure using either 82 deg flat head screws with flange cup washers or (worst case) button head screws and large flat washers. The point is to minimize the disturbance to the airflow caused by the screw heads. Be sure to use thread lock on them.
To engineering help
Quick Reply: engineering help
