what weight oil do you run?
Not the brand as the "what's better" will take over...I use 15w50 and in This weather I hate it take 5-7 seconds to get pressure in this cold...thinking of running a 0w40
so...whats the point of running a 15w? if that is the W at cold, why wouldnt we all want 0-5W to move through the motor faster on start up?
I believe its because of the additives, like the zinc are in such high quantity that the government does not like it (emissions I suppose).
Zinc (aka zddp) is absolutely crucial for preventing engine wear. M1 5w30 used to have zddp, but the new formulation doesnt have any.
It is the phosphorus component of ZDDP that poisons the catalytic converters. A race oil might have 2500 PPM of ZDDP, 4X-5X the level of a SM rated oil. Even modest levels of blowby past the rings will degrade the cats. ZDDP excels in providing boundry layer lubrication; when your oil film degrades due to high g's or loss of oil pressure.
whats the name of it?
Amsoil 0W30 synthetic mixed with Amsoil 10W30 racing oil. The racing oil has high zddp for engine protection, but no detergents so you have to change you oil frequently. That's why I mix 50/50 with regular synthetic for the best of both worlds. BTW, you can get a preferred customer discount with Amsoil and they will ship everything directly to your house including filters etc.
For serious track cars xxW-40 or xxW-50 oils makes sense. The 50's are pretty darn thick, and honestly I don't think you need to run one unless you've either rebuilt the engine with loose tolerances or are seeing 300F.
Also just because one oil claims it's a 0W-40 and another a 5W-40, doesn't guarantee that the 0W-40 is ANY thinner when cold.
I run a 5W-40 HD oil made from group 4 & 5 base stocks with a strong additive anti-wear additive pkg, and decent detergent pkg. Thin enough to where I get oil pressure instantly & have good pressure when hot at the track.
Another option if you run thicker oils is an oil tank heater.
My car sees mostly street use...hard use, but the street. think I better switch to a 0w-40.
I was running 15-50 because my 416 LS3 would get to 240* with just driving around in the summer. 260-270 with romping on it. This was after I installed the splitter and before the oil cooler.
